Reflectors in. Not as much of a "drop-in fit' as I would've liked, but I knew some of my horn panels were off a little bit. Nothing liberal application of PL didnt' cure.
This design "flaw" is actually there to provide room for a finish. If this was to be a furniture quality finish, then I could understand the need for a smaller gap. But, using either a durable painted-on finish, such as Duratex, or carpeting, that gap will diminish quickly.miked wrote:Anway, last night I was just test fitting the sides and the back and I noticed that my back panels are too short both in height and width (absolutely USABLE, but not optimally sized). They measure 13 3/4" x 20 3/4", per the plans, but the space they must fill is 14.0" x 21.0". I guess this was probably an intentional design decision to leave a little wiggle room for the Backyard Bunglers out there. But now my rear panels will have a 1/8" gap all around. Not a huge deal as the back panel braces are 1" all around. No way I'm making 4 new panels, but if I would've caught this fact earlier, I'd have made my rear panels 13 7/8" x 20 7/8".
It should take up about half the space. You don't want the back panel to be a friction fit, so a tiny gap is actually needed. A 1/32" of Duratex is easily two coats... x 4 edges (2 on the panel, 2 on the cabinet) and you've totally removed that gap.miked wrote:Though I don't really see it taking up 1/8" of space all around. If I was using carpet, then the extra space would be a non-issue.
Got it on the tape; thanks much.DJPhatman wrote:Use enough gasket tape to prevent any leaks. Leaks kill response. With the 1/2" wide tape, I would do 2 strips, butting up against each other, with the screws going through at the seam where the strips butt together. This will insure a good seal, and seal the screws from leaking.
Put the HP/LP filter board wherever it is convenient. Make sure you test fit with the driver installed before you commit to anything on the back cover.
You're right....it won't fit. I put mine on the side panel. If I was doing it over again, I'd glue a little 1x2" strip of ply on the side before putting on the foam to mount the xover to. Screwing into the 1/2" side doesn't leave much room for a good bite without going through.miked wrote: Would be SO NICE to mount the xover dead center, b/t the braces, but it probably won't fit.
miked wrote:Thanks for that tip, Bruce. I will glue the strip(s) to the side panel before putting the foam on. Great tip. The last thing I want to do is bust through the side panel...after Duratexing. That wouldn't be good.
Bruce: BTW, how did you secure the foam behind your grills? I'm obviously not at that point yet, but trying to figure it out in advance. I'd be worried that spray glue (ala 3M 77) would leave the grill all sticky.
Mine sit outside in the trailer and I haven't had one come off yet.....with makes me think I had better go check 'em before the gigs start again.miked wrote:Spray the grill. That makes perfect sense, which I why wouldn't have thought of it. LOL! Any issues with the foam separating from the grill? With garages down here easily hitting 120F in the summer time, if they haven't separated by now, they probably never will. Thanks.
You can get the AC foam at Walmart. It's a perfect fit for the OT12s, just trim a little off. No splicing.miked wrote:Outside in the trailer? That would be 150F+ inside the trailer in the Jul-Sep timeframe. If they've not come off yet, they never will. I'll be going the 3M spray method then. Thanks.
I have YARDS of black grill cloth that I bought from PE probably 10 years ago...can't figure a way to make it work with a metal grill. I'm sure a few hours of tedious sewing would secure the fabric to the grill, but the sharp edge of the grill material will make short work of the cloth. Oh well.
