Page 6 of 7
Re: Curved Grill WH10
Posted: Thu May 26, 2011 5:33 am
by Harley
Dave Non-Zero wrote:yeah but the point is - you thought about that before doing it.
OMG
Don't say they've actually finally found a man who follows instructions
Wonders will never cease.
Posted: Thu May 26, 2011 5:55 am
by Dave Non-Zero
next he will be asking for directions when he is lost!
Posted: Thu May 26, 2011 9:05 am
by N.Webber
The throats closed with foam plugs:
The trimmed quartet:
The quartets cleaned from the cutting residues and ready for gluing:
Arrays glued and left to dry:
Posted: Thu May 26, 2011 10:41 am
by mpm32
Wait, the grills get their own jig but the poor arrays just get to get glued on a piece of square stock? No jig for the glue up?
Posted: Thu May 26, 2011 1:18 pm
by matthewmdn
That is beautiful work!
So someone was saying that they liked the colored piezo arrays and that was making me wonder. Can you paint these arrays or did they find hot pink piezos on ebay? I really like the colored arrays too.
Thanks for the answers on the DIY glue too. I am totally going to try it.
Posted: Thu May 26, 2011 1:27 pm
by jswingchun
mpm32 wrote:Wait, the grills get their own jig but the poor arrays just get to get glued on a piece of square stock? No jig for the glue up?
LOL, I was going to ask why no pictures of the 45 degree angle cutting jig after seeing the pics of the jig for cutting the sides.
Posted: Thu May 26, 2011 1:33 pm
by N.Webber
The Piezos already got their share of fancy jigs...
K.I.S… I.P
(If Possible…)
Posted: Fri May 27, 2011 7:29 am
by N.Webber
The melded arrays are melded…
I must say I am really impressed with this DIY glue. Very easy to apply, and the result looks as if it was joined by Ultrasonic welding:
The arrays wired:
Diffusers installed:
I've arranged this test setup to see what the melded arrays actually produce:
This is the response curve:
Not so clear in the picture, but the Piezos 'wake up' just over 1 kHz. With the X-over high passing at around 1.5 - 2kHz that looks good.
The two significant peeks at 4kHz and between 6 and 8kHz will be easily trimmed with the send EQ.
Next: final assembly
Posted: Fri May 27, 2011 9:46 am
by N.Webber
Forgot to show a little tip/trick regarding attaching the melded array diffuser…
Before attaching the diffuser tube to the array, I folded around it a long piece of fine grit sandpaper,
and while pressing it lightly in its intended position, I slid it along the tube axis up and down a few times.
This achieved two things: it marked exactly where the contact points are so I knew were to put the adhesive,
and also it roughened those points a little so the adhesive would grip better.
Here after marking with the sandpaper:
I used black silicone compound for attaching the diffuser tube – a bead to each mark/point.
The diffuser tube is made of 16mm (5/8") house plumbing pipe.
Its outer and inner layers are Polyethylene and an Aluminum layer in between (locally known as SP)
Here a close-up of the contact points (and pipe section…):
Posted: Fri May 27, 2011 2:00 pm
by Harley
I can't get black pipe here the right dia, so I have to settle with grey and spray paint it black!
Posted: Fri May 27, 2011 3:55 pm
by matthewmdn
So does it do anything to the sound to paint the whole thing when it's done. If it's ok to do what prep/paint should be used.
Posted: Fri May 27, 2011 5:32 pm
by Kirk Baptista
I found some 5/8" clear acrylic tubing and spray painted the inside. Came out nice and shiny!
Posted: Fri May 27, 2011 9:27 pm
matthewmdn wrote:So does it do anything to the sound to paint the whole thing when it's done.
Only if you listen with your
eyesmatthewmdn wrote:If it's ok to do what prep/paint should be used.
A little scuffing...and some Krylon in a rattle can. And your done!
Posted: Fri May 27, 2011 9:46 pm
by SeisTres
Tom Smit wrote:matthewmdn wrote:So does it do anything to the sound to paint the whole thing when it's done.
I have never bothered to paint tweest, but shouldn't the opening be plugged up since the new piezos are glued?
Posted: Fri May 27, 2011 10:08 pm
SeisTres wrote:Tom Smit wrote:matthewmdn wrote:So does it do anything to the sound to paint the whole thing when it's done.
Yup, that too.
