What's to chat about?
Re: What's to chat about? Supertonic
#706 Post by Bruce Weldy »
Tom Smit wrote: Tue Sep 22, 2020 11:14 pm I just learned about the supertonic https://www.youtube.com/watch?v=tR32h5j ... QpFEJRk2Zw
I, also, learned that "The Weekend" has a number of songs that have the same melody (it's in the video).
I found the video interesting......however, I have never heard a single song that he played.....
#707 Post by Seth »
Bruce Weldy wrote: Wed Sep 23, 2020 7:54 am
Two lessons in one! What a bargain! LOL
#708 Post by Bruce Weldy »
SethRocksYou wrote: Wed Sep 23, 2020 9:40 am
Unfortunately, the second lesson was - new music really sucks. Its only redeeming value is that it has made disco more palatable on the suckiness scale. :mrgreen:
#709 Post by Seth »
DANG you guys! If it stays this slow around here, I'm just going to have to take matters into my own hands and complete the four 30" T39's I have sitting here in piles of pre cut plywood panels. :cussing:
#710 Post by Seth »
Hey Bill, I had a random curiosity. The splay angles that the DR's are designed with, I noticed they're all different. Is that angle chosen based on how they stack, to create a particular curve for a certain stack height? Or, does it have something to do with creating the horn flare (not sure if that's the correct term) to attain the desired response? Or... something completely different?
#711 Post by Chris_Allen »
It is probably to create the correct mouth area in relation to the throat.
#712 Post by Seth »
Chris_Allen wrote: Thu Oct 15, 2020 5:17 am It is probably to create the correct mouth area in relation to the throat.
I though it may also have something to do with that whole parallel surfaces anomaly thing too. Dunno. Oh well.
Do I recall correctly that you put two DR200's together in about 12 hours start to finish?
Strange Kevin
#713 Post by Strange Kevin »
12 hours Start to finish Dr200????
Well, call me impressed!
I'd love to see a time laps of that! :)
When I build some DRs its more like 12 days, not hours!
#714 Post by Seth »
Are any of you guys following Wintergaten - Martin Molen's build series of the MMX (Marble Machine X) on YouTube? It's absolutely incredible from so many aspects. Engineering, woodworking, personal development, overcoming obstacles, organization, and more.
It's a build series of the new and improved version of this:
NukePooch
#715 Post by NukePooch »
SethRocksYou wrote: Thu Oct 29, 2020 3:43 pm Are any of you guys following Wintergaten - Martin Molen's build series of the MMX
I check in on occasion, but because he keeps ripping it apart for the 58th time, I don't watch all the videos...I'm more of a 'check in every quarter and see what he's tearing apart now' kind of viewer...If/when he completes it, it will be absolutely incredible/insane!
#716 Post by Seth »
NukePooch wrote: Thu Oct 29, 2020 4:30 pm
I look forward to Wednesday's for every update. They're not always enthralling and sometimes I'll stop one early if it's not holding my interest. But, I find it to be quality entertainment 95+% of the time.
#717 Post by Seth »
Amplifier thought/question;
Two T39's and an amp rated 2x 150 @ 8ohm, 250 @ 4ohm, 500 bridged @ 8, RMS.
If brick wall limited to 45 volts and bridged into 4ohms, how likely is it that the amp would do so cleanly without going into any over-temp protect modes? (netting 250 per cab, instead of 125 if not bridged)
#718 Post by Grant Bunter »
SethRocksYou wrote: Tue Nov 17, 2020 3:11 pm Amplifier thought/question;
Ummm the specs don't say, from what you've given us, that you can put a 4 ohm load on the amp when bridged.
Plenty of amps are very picky about correct impedance loads in bridged mode and how they will behave...
#719 Post by Seth »
Grant Bunter wrote: Tue Nov 17, 2020 3:48 pm
You're right, the specs don't specify that it can. However... they also don't specify that it can't.
There are a lot of late model amps that are auto load sensing and internally regulate output based on the load impedance. I'm curious if it's likely that doing the task manually (via signal limiting) could also be effective.
Based on the nominal impedance, the difference in amperage in the circuit is 3.3 amperes, or about 42% increase from 500 watts at 8 ohms (7.9A @ 63.24V) and 500 watts at 4 ohms (11.2A @ 44.72V). I wonder how likely it is that the average amplifiers power supply and output transistors can cover the additional amperage. I'd imagine that the overall efficiency of the amplifier wouldn't change more than 5% or so. But, I really don't know all too much about amplifiers other than basic principals of operation.
Just a thought and consideration I had , that I thought was conversation worthy. What do you think? What's your gut or logic tell you?
#720 Post by Bruce Weldy »
Here's the short answer.....if the amp is 2 ohm capable per channel, then it can be bridged to 4 ohms. If it is only listed at 4 ohms capable per channel, then you can't bridge it to 4 ohms.....just 8.
A good example of this is the QSC GX series...they are good amps, but not 2 ohm capable, so no bridging to 4.
