First BFM Build Odyssey: Tuba 60
Re: First BFM Build Odyssey: Tuba 60
#61 Post by Bruce Weldy »
Joman116 wrote: Sun Apr 19, 2026 11:15 pm
Tom Smit wrote: Sun Apr 19, 2026 9:44 pm
Joman116 wrote: Sun Apr 19, 2026 7:28 am I will 100% be doing a driver fit test, driving the RECEX screws in, before adding panels, forgot to mention that.
Predrill the screw holes in the blocks first, before driving the screws in, okay?
Got it.
I've always used 3/4" brads - set to the deepest setting. 1" can go through two thicknesses of ply. Plenty of hold while the PL dries.
Joman116
#62 Post by Joman116 »
All right folks I have returned. I test fitted the driver and installed it with the recex screws. I ran the 20 Hertz test tone. There's a lot of vibrations so it's really quite difficult to determine if the speaker cone surround is hitting the baffle. The sounds that I hear are either the piece of wood or the table vibrating I believe. Visibly I don't really see it touching.
Won't be getting around to next steps till beginning of June.
QSC 1804 Amp
In Progress: 1x20" Tuba 60 loaded with Eminence Lab12
#63 Post by Tom Smit »
Did you try the trick of coating the roll with chalk, and then trying it?
Joman116
#64 Post by Joman116 »
Tom Smit wrote: Wed May 13, 2026 9:05 pm Did you try the trick of coating the roll with chalk, and then trying it?
I put the order in yesterday so the chalk should arrive today. I was trying to avoid buying another piece of apparatus but don't want to screw this up.
QSC 1804 Amp
