Page 5 of 5
Re: T48 stack
Posted: Sat Dec 02, 2023 3:01 pm
by jakkle21
Seth wrote: Mon Nov 20, 2023 10:23 am I want to help you set this rig up and get it dialed in. Over several days, I've typed up really long responses for this thread, then chosen not to post them for whatever reason.
I am definitely still lurking around the forum, and I am absolutely interested in getting this all set up right and dialed in. Ive had a few much longer and in depth posts and replys typed up that Ive either lost or just not posted so I understand that.
I've mostly just been very busy with the "day-job", getting ready for winter and doing tons of neglected car repairs.
I've also been thinking about starting a new thread over on the "pro-sound" board, tockeepcthings more organized, and not fill up my build thread with too much unrelated tech talk, but havent gotten around to it.
I'm also still saving up for the plywood to build the second pair and I've most settled on a color (or two) to paint them
Tldr: I am very interested in and grateful for any help getting this system running better
Re: T48 stack
Posted: Tue Dec 05, 2023 2:07 am
by Seth
Instead of trying to put it all into one post, I'll trickle all I have to offer in little bits over a few days or weeks.
jakkle21 wrote: Sat Sep 23, 2023 2:34 am ...I set my limiter to just over 50V...
Set your limiter to 60V. I'm not sure how you went about setting your limiter. But just to be safe, here's a quick explanation of how to do it to properly protect your drivers. You don't have to have the whole system set up to do this, you can do it on your kitchen table with just the amp, Driverack, sinewave source, and a digital multimeter.
- Disable any highpass and lowpass crossover filters on the subwoofer channel
- Disable or turn off any feedback suppression functions
- Disable Subharmonic synth
- Disconnect the speakers
- Turn the amplifier gains all the way up
- Use an online tone generator (or or any other source) and play a 60Hz sinewave.
- Turn the source volume up until the clip indicator just lights up on the amplifier
- In the Limiter settings in the Driverack, turn "overeasy" off
- Set your digital multimeter to read AC voltage and place the probes to read voltage across the amplifier outputs
- In the Driverack Limiter settings, slowly reduce the threshold until the multimeter reads as close to 60 volts without going over. It won't matter if it's a couple volts below 60, if that's the closest you can get without going over.
- Once set, reduce the volume and rapidly flick it up again a few times and verify the voltage does not exceed 60V.
- Your limiter is now properly set to protect your drivers.
I tried my best to wall/corner load them, but was kind of limited by the layout, but over all I was happy with the placement.
Very cool and educational to get to experience that first hand
I'm happy to hear you've read the placement sticky and are practicing intentional proper subwoofer placement and deployment tactics. That really is a huge step in getting the most out of your system. However, it's unfortunate that for the most part, wall and corner loading are primarily effective for indoor venues. The reason is, for a boundary to effectively reflect a soundwave it must be at least one wavelength tall and twice that in width. Where indoors, walls and corners become floors and ceilings, average size boundaries outdoors do not extend and become ceilings. In any case, I like your placement too. It looks like an appropriate spot. And if bass coverage was mostly even throughout the intended listening area with the subs there, even better.
In looking at the photo, there's a couple obvious opportunities to improve your system. The first is simply to construct a V-Plate and use it every time you're able. The second one is another simple and inexpensive upgrade. Invest in a few budget speaker stands to get your JBL Eon's up and above the listeners heads. I have no experience with the specific brand in the link.
In the pic, I like that you have the two JBL's splayed inward. It should help in minimizing comb filtering when compared to splaying them outward. :thumbsup:
That's it for now. BTW, having experienced these two cabs, are you still planning to build the second pair? I hope so. That would be awesome! Just knowing another highly capable system exists out there in the world is oddly satisfying on my end.
Re: T48 stack
Posted: Thu Aug 29, 2024 12:51 am
by jakkle21
Hello all.
Sorry for the long absence.
Life and the day job have been busy.
I have finally gotten started finishing my first pair.
They are sanded, caulked, routered, primed and the first coat of duratex is on them.
I have two events coming up next month, on consecutive weekends, that I have to run my system at.
I have also checked and replaced the gaskets on my access ports, as well as built a matching triangle, and brance to set them up in a v-plate configuration. The brace is for the middle of the v-plate, and so that I don't have to worry about people sitting/dancing on the subs.
I am still planning on making more, it's just been a slow process. But I have all of the materials to make the next pair.
Then my plan is to work on tops and monitors, to replace all my self-powered JBLs. But that part is probably a way out
Re: T48 stack
Posted: Thu Aug 29, 2024 9:26 pm
Life...yup!
Wishing you success at your two gigs coming up.
Re: T48 stack
Posted: Sun Nov 03, 2024 5:36 pm
by jakkle21
I have more pictures of the painting/finishing, but they are on another memory card, that I have misplaced somewhere.
They were primed and given a single coat of duratex. Both tinted purple. With the braces in the mouth painted white.
V-plate and brace painted to match.
I added the vertical brace to the v-plate sopeople could dance and sit on it, and I am on replacing it with fancy bracing that looks nicer and matches the subs.
Anyway, they preformed great. The V-plate made an immediate, noticable difference. The bass was plenty loud, and clean enough to have a normal conversation right in front of them. Even our old buddy who doesn't really like bass and electronic music was impressed with how you can feel the bass without it blasting your ears.
Setup from second event, DJ booth in the middle.
At night with lighting
Re: T48 stack
Posted: Sun Nov 03, 2024 11:10 pm
Cool beans! Good to hear that you experienced the advantage of the V-plate.
Re: T48 stack
Posted: Mon Nov 04, 2024 7:07 am
by dlv
Love the purple look! Especially lit up. Can't wait to get my build done. It's getting close.
BTW I'm in Prescott. We're practically neighbors! Lemme know if you get down here ever.
-Dave
Re: T48 stack
Posted: Thu Nov 21, 2024 5:33 am
by jakkle21
I'm extremely happy with how they came out. Time will tell how well the relatively light colour handles wear and tear, but I got enough duratex to give them another coat and do touchup as necessary.
Dave, good to know there's more builders around these parts, I'll have to try and see them when your whole herd is done.Just read through your build thread and everything is looking great
Re: T48 stack
Posted: Fri Nov 22, 2024 1:36 am
by Seth
I just flipped back through the thread a page or two and realized which project this was! I'm really happy to read an update about this deal. That's awesome news! Thank you for taking the time to share the win. They came out looking really good and I like the artistic décor framing the stack as the centerpiece... especially with the lighting. Well done.
After having used the pair, what are your thoughts about building the other pair?
