OT12 and T48 combination
PulseMan
Re: OT12 and T48 combination
#61 Post by PulseMan »
maxo wrote:hey
what would be the synq amps alternatives in the usa
looks like synq only sells overseas
Hi maxo I think the USA bofs will have to answer that one.
I'm sure there should be a QSC / Crown equivalent with the same or better specs in the USA.
They are so over priced here in South Africa that QSC or Crown are not worth it.
PulseMan
BUILT
8 T48's 24" 3015LF LOADED
2 WEDGEHORN 10 MKIV's
1 SLA PRO FOR CENTRE FILL
Like us on facebook
https://www.facebook.com/Pulse.Entertainment.SA‎
fyah2k5
#62 Post by fyah2k5 »
Awesome setup. Wonder how good this would sound playing recorded music, like a DJ setup, playing hip hop, reggae, etc?
My question to you though, what's that device controlling the electricity on top of the amp rack? Looks interesting.
maxo
#63 Post by maxo »
It is a 3 phase power distribution panel
with thermal breakers and volts plus ampere digital readings
that way you know at a glance how many juice your amps are sucking
http://en.beglec.com/product/4626/PD-32A
same guys that made the amps
http://en.beglec.com/product/267/DIGIT-3K6
It is not the bananas but the monkey
maxo
#64 Post by maxo »
PulseMan wrote:
maxo wrote:hey
PulseMan
Hey Pulse
the thing is that in the USA i havent see a crown or qsc or peavey or behringer that in a single rack space
cram this much power
normally they are 2 rack spaces
PulseMan
#65 Post by PulseMan »
Hi guys
Sorry for late reply, crazy time of the year.
fyah2k5 wrote:Awesome setup. Wonder how good this would sound playing recorded music, like a DJ setup, playing hip hop, reggae, etc?
I have used this combination with most of the styles you've mentioned and no issues at all. Bit of tweaking on the desk if needed and you good to go.
maxo wrote:the thing is that in the USA i havent see a crown or qsc or peavey or behringer that in a single rack space
cram this much power. normally they are 2 rack spaces
Possibility of importing these synq's to USA?
PulseMan
BUILT
Like us on facebook
fyah2k5
#66 Post by fyah2k5 »
Those looks good. Thing is the power I have in jamaica, or have most access to is single phase 220 and 110. I'm gonna look around if I find any of those.
Thanks man, awesome rig.
Charles Jenkinson
#67 Post by Charles Jenkinson »
I've been impressed by this review of the synq amps. FWIW, the offerings available to me in the UK, at the 300w/8ohm mark are:
Crown XLS 1500. £340. 2U
QSC GX3. £250. 2U
Matrix XT800. £400. 1U
Synq dig01k. £260. 1U. 3.5kg
I had matrix recommemded for quality but at another £140, I'm not sure its worth it.
2xT30
PulseMan
#68 Post by PulseMan »
Charles Jenkinson wrote:I've been impressed by this review of the synq amps. FWIW, the offerings available to me in the UK, at the 300w/8ohm mark are:
QSC GX3. £250. 2U
I had matrix recommended for quality but at another £140, I'm not sure its worth it.
Don't know these other amps and can't comment on them unfortunately.
I have used these amps extensively this past year with big crowds and most of the the time at "War volume" due to the sizes of the crowds that attended most of the shows and these babies were rock solid so far. The big brother 3K6, I've had for over three years already running the subs before I built the OT12's and still good.
I will buy more of these synq's without any doubt when the need arises again.
PulseMan
BUILT
Like us on facebook
Bas Gooiker
#69 Post by Bas Gooiker »
TimpBizkit wrote:Nice, Looks like that gets friggin loud and clear!!
I like the foam too - makes them look like 'HK Audio' stuff.
I looked at the plans for the OTop and MUCH easier than DRs!
Do you have any plans for more subs to match all those tops or do you not need enough total volume (or you play music with less bass) to care about transporting all the extra kit?
Sorry if this has been answered elsewhere. What speakers are you using in OTops and subs?
Deltalite 2512, 3012HO?
Kappalite 3015LF, 18Sound 15NLW9300, Peavey Low Rider?
Did you only look at the pretty pictures or do you also read all those words people use to fill up the rest of the page?
Each of his posts has a signature saying the tops are Delta Pro 12 loaded, the subs with 3015lf.
88h88
#70 Post by 88h88 »
QSC GX3. £250. 2U
Where's offering the Synq for 260 quid? I might give one a go.
Charles Jenkinson
#71 Post by Charles Jenkinson »
Terralec; they're the (seemingly sole) UK distributor for Synq, from when I looked at the Synq website a few months back. Might be worth a bit more digging see if there's anyone else. Good luck.
http://www.terralec.co.uk/power_amplifi ... 674_p.html
2xT30
88h88
#72 Post by 88h88 »
I've had a look and it seems like Terralec are the only place that currently stocks them. I'll have another look when I'll be grabbing one. Thanks.
tartan
#73 Post by tartan »
maxo wrote:Hey Pulse
PowerSoft is available in the USA, but they're not cheap! Here's their K series:
http://www.powersoft-audio.com/en/produ ... eries.html
Josh
Atlanta, GA
THTLP, former owner of T48
sine143
#74 Post by sine143 »
those things are scary! 18k watts in 1u? what? :chainsaw:
#75 Post by AntonZ »
sine143 wrote:those things are scary! 18k watts in 1u? what? :chainsaw:
Comes pretty close to the flux capacitor (1.21 jigawatts of electrical power) that supposedly drives Leland's workshop 8)
