Niceeeeeee !!!!
i like it
hey is that some crowns XLS's at the bottom of your rack
OT12 Build
Re: OT12 Build
It is not the bananas but the monkey
Re: OT12 Build
Yep.
XLS 1500 bridged for subs and 2500 on mains. xTi 2000 on monitors.
Re: OT12 Build
Nice
what you use for wedges
( i only see subs and tops on your signature )
hey bruce according to some reading i have done here
you must avoid at all costs amp bridging
a spike can fry your sub drivers
But i think you have never experienced that
what you can say about the subject
Re: OT12 Build
Processor on mains I expect.
Re: OT12 Build
I use Yamaha SM15V monitors. 15 and a horn. They sound good and have a lot of bottom end....they don't require a lot of EQ.maxo wrote:Nice
I bridge the 1500 for the subs - it's not a lot of overkill as it's only 1100 watts at 4 ohms....the subs can take 900 total, but I have 'em limited to 56 volts. I like the headroom. I tried the xti 2000 but the inputs were clipping, the 1500 doesn't. I've run the XLS series bridged for two years. As Bill says, only bridge when you can't get the voltage any other way. None of my amps will give me enough without bridging - so I bridge the smallest one to get what I need. I wouldn't bridge if I had an amp with more power, but this fits my needs just fine and it is ALWAYS limited.
Re: OT12 Build
???Gregory East wrote:Processor on mains I expect.
I use a driverack if that's what you mean. I know the 2500 seems like a lot for the mains and it is....but, I was able to get it really cheap so I picked it up. Obviously, it just idles driving 4 OT12s.
Re: OT12 Build
(Speaker) Processor, common enough usage in BFM.Bruce Weldy wrote:???Gregory East wrote:Processor on mains I expect.
Mains = front of house, maybe a kiwiism?
Re: OT12 Build
Actually, mains refers to tops (that are FOH).....should have said it that way.Gregory East wrote:(Speaker) Processor, common enough usage in BFM.Bruce Weldy wrote:???Gregory East wrote:Processor on mains I expect.
