DR200 (x4) Build Thread
Scott Brochu
Re: DR200 (x4) Build Thread
#46 Post by Scott Brochu »
David Carter wrote: I was nervous going into the test because of the problems Scott had with his after following my wiring diagram.
I think I wired it wrong but know where the problem is now. It was not your drawings, it was my following.
David Carter wrote: This close-up exaggerates many of the imperfections due to dust and lighting, but as you can tell, my array is not perfect. But at this point, I don't have the patience to do any more work on it, so it's staying like it is. Fortunately, it doesn't look as bad from a few feet away. :lol:
Can't see it from my house :mrgreen:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
SoundInMotionDJ
#47 Post by SoundInMotionDJ »
David Carter wrote:This close-up exaggerates many of the imperfections due to dust and lighting, but as you can tell, my array is not perfect.
Those are at least as good as I managed...on my second batch. My first batch is considerably rougher looking that that.
Great job!
--Stan Graves
10 T39S + 10 DR200 + 1 T48
more4me
#48 Post by more4me »
Very nice build !
Is there any special gain in cutting out the vent slots after assembly as opposed to cutting out the vent slots before?
I'm a bit concerned cutting with a jig saw since it vibrates ALOT, it would perhaps overstress the joints?
Builds so far:
2x T39
2x Omni15TB
2x DR200
1x Omni10
Born Confused... and grown worse...
David Carter
#49 Post by David Carter »
more4me wrote:Very nice build !
I wondered the same thing myself, but I ended up just following the sequence in the plans. I don't know what adhesive you are using, but for those who use PL, the stress on the joints is not a problem. There is no way that the PL will come loose if you've let it cure well. The wood would break before the adhesive will fail.
Dave
- 2 x Titan 39 (BP102 - 14"W)
David Carter
#50 Post by David Carter »
Been working on melded arrays while I wait for more Duratex to arrive.
And while I wait for the ABS cement to dry on the arrays, I took some time to crank out a case for my mics whose ABS cases are falling apart. I pulled out the foam insert from the ABS cases, built a wood box around them, added some rat fur I had laying around, and voila...
Now I've got both sets of mics in one case. Just need to add hinges, latches, and a handle, and I'll be good to go. :D
Dave
Scott Brochu
#51 Post by Scott Brochu »
very good use of time and materials :mrgreen:
#52 Post by Tom Smit »
:clap: good multi-tasking.
Harley
#53 Post by Harley »
If you got a shot of your complete workshop, it almost looks like you'd qualify for the coveted '5 Harley' award
#54 Post by Tom Smit »
Harley, you didn't look too close :lol: (bottom left of pic)
David Carter
#55 Post by David Carter »
Harley wrote:If you got a shot of your complete workshop, it almost looks like you'd qualify for the coveted '5 Harley' award
Unfortunately, I think the only award I qualify for is the "skilled photo cropping" award. There's a reason I crop most of my pics to NOT show the surrounding area. :lol: Maybe I'll take a pic of it after I finish the cabs and get it cleaned up. :D
Dave
David Carter
#56 Post by David Carter »
Got the melded arrays all glued up and spray painted. Still have to wire all but one of them...
Also got the last two boxes primed with the flat latex. Hope to roll on the Duratex later today...
Dave
Scott Brochu
#57 Post by Scott Brochu »
David for what I can see in the bottom photo, I wouldn't worry about your garage cluter. It looks like you have a tidy garage; storage containers on a shelf indicates that your neat. I will put my vote in. :clap:
Oh ya! good job on the array :mrgreen:
David Carter
#58 Post by David Carter »
Scott Brochu wrote:David for what I can see in the bottom photo, I wouldn't worry about your garage cluter. It looks like you have a tidy garage; storage containers on a shelf indicates that your neat. I will put my vote in. :clap:
Thanks. My approach is usually to be very neat and organized when I'm not in the middle of a project. But when I really get into a project, I don't spend a lot of time putting away things that I'm just going to go find again the next morning. I also don't spend a lot of time disposing of scraps or cleaning up sawdust until the end or until I can't get to the other side of the garage without risking life and limb. :)
Dave
David Carter
#59 Post by David Carter »
Got a fair amount done on Saturday. Got all the wiring done on the melded arrays...
Also got the last filter wired up and all the filters mounted to the underside of the access covers...
Also did some routing on a couple of the access covers for the adjustable top hats, but I didn't get pics of that.
Here's a group shot. They are still far from finished, but I was just test fitting the arrays to make sure I could get them in. After some sanding, grinding, and even a little trimming off the ends of some of the arrays, I finally got them to fit well...
Dave
Turntablist
#60 Post by Turntablist »
It's looking damn good Dave 8)
-2 T48 3015LF
-2 DR250 2510 crossfired
