Low cost Class D pro plate amps.
Re: Low cost Class D pro plate amps.
#46 Post by Grant Bunter »
chris_c_ wrote: Grant, about pricing and product, your feedback would be a help: Which features would you require? Which features would you like to have but not absolutely require? How much would you be interested in paying?
I've tried to say more than once elsewhere here in the forum I'm not interested.
Unless the plate amps have every feature under the sun, with enough power, and are free.
Even then, in a new build, I wouldn't want to be adding more material for a plate amp chamber, changing weight, or centre of gravity for each cab, buying a whole bunch of (my) standard outlet plug to IEC power cables, etc etc etc.
When I initially commented, I said I was only interested from a price point perspective.
And the reason I was interested in that perspective is I maintain one could buy a smaller amount of regular power amps vs plate amps, for the same, or less, cost. Some of that is also that I can run (with the right amp) at least 4 cabs per regular power amp.
Regardless of features, for the plate amps to be attractive as an option (for those that may be interested), they would need to cost 1/4 the price of a regular power amp that will do 4 cabs in order to be price competitive. Or, if they do have DSP including EQ etc, then they need to be the same price (or lower) as however many regular power amps and a driverack (for example) any given user will require otherwise...
chris_c_
#47 Post by chris_c_ »
Trust me Grant you're with me on this, I'm interested in doing this plate amp such that its performance and cost per channel are exceptional.
Newest mix 8) https://facebook.com/BEATJACKERmusic "Like" appreciated :D
#48 Post by Grant Bunter »
chris_c_ wrote: Trust me Grant you're with me on this, I'm interested in doing this plate amp such that its performance and cost per channel are exceptional.
Chris,
Trust me, you're wrong on that assumption.
Even if you can do what you say, shipping from the USA would kill any potential for me (because I can buy regular power amps here in Australia right now with the specs I need), and, I'm not interested.
Still, get on it for your fellow country mates who are interested.
This thread is nearly 2 months old already, and all I can see is you waiting for people to tell you what they want are are willing to pay before you even get started.
Go the other way around. Talk to your manufacturer and work out pricing, get it made, sell them...
MulletOver
#49 Post by MulletOver »
Enjoying the discussion so far! I was toying with the idea of a plate amp recently for my subs. I picked up a salvaged plate amp from a JBL SRX815P cabinet a few months ago for $50. I estimated that I could run up to (4) T39's off of it, but I can't install it in any of my current cabs.
So, if I built another T39, I know I would need to extend the cabinet somehow/somewhere - where would be the most practical place to mount the amp? (And Bruce, don't say 'the rack' ;-)
(8) 19" T39s (4xLab12, 4xDelta12LFA)
(4) SLA-PRO (4x6") Alpha6a
(1) Simplexx 10" wedge
#50 Post by Bruce Weldy »
MulletOver wrote: (And Bruce, don't say 'the rack' ;-)
In it's own little box? You could put it on top of the rack.
Pretty sure that JBL amp is rated at either 4 or 8 ohms, not 2.....so, 2 T39s would be the max on it. Hard to find the specs on the amps in the powered speakers. Typically the single driver boxes are 8 ohm and the double drivers are 4 ohm. They probably use the same plate amp in those, so I'd guess that it's 4 ohm.
You can bet that those amps have built-in DSP specific to that particular box - I kinda' doubt that you'd be able to re-program it to be just a naked power amp.....I could be wrong.
Of course, you'll still need a limiter....that will be in a rack......hmmmm.....back where we started.
Rich4349
#51 Post by Rich4349 »
Or maybe bolt it right onto the front face angle of the horn mouth? Sure, it'll disrupt 100% efficiency, but Bill's horns are so damn efficient- what's 3-4% lost? Vibrations? Yeah, there are going to be SOME, but again, these cabs are so damn well braced. Besides, it's a $50 amp- EXPERIMENT! Cabling could be a bit ugly, so... go Steampunk! Dress em up, paint em bronze? Add in a few superfluous cable coils? Idk.
Bruce Weldy wrote: Pretty sure that JBL amp is rated at either 4 or 8 ohms, not 2.....so, 2 T39s would be the max on it... Typically the single driver boxes are 8 ohm and the double drivers are 4 ohm.
So go series / parallel? Parallel 8/2=4, series them right back up to 8? Not much wattage split 4 ways (edit: 800w, so not *too* bad), but a fun cheap experiment.
#52 Post by Bruce Weldy »
Rich4349 wrote: So go series / parallel? Parallel 8/2=4, series them right back up to 8? Not much wattage split 4 ways (edit: 800w, so not *too* bad), but a fun cheap experiment.
Yep....more cables per box plus specialty cables/box to wire in series.....yep, those plate amps make everything easier..... :mrgreen:
chris_c_
#53 Post by chris_c_ »
MulletOver wrote:Enjoying the discussion so far! I was toying with the idea of a plate amp recently for my subs. I picked up a salvaged plate amp from a JBL SRX815P cabinet a few months ago for $50. I estimated that I could run up to (4) T39's off of it, but I can't install it in any of my current cabs.
1. Measure the volume of the JBL SRX815P plate amp (the part that sits inside of the cab) in cubic inches.
2. Divide by the area of the back of the T39 cab in square inches.
3. Equals the number of inches of depth to add to the T39 cab.
4. Building the "deeper" T39.
5. Cut correct sized rectangle in the back of the T39 to hold the JBL plate amp.
6. Add 3 speakons to the back of this cab, series-parallel wired power amp outputs to the 3 other T39's.
Rich4349
#54 Post by Rich4349 »
chris_c_ wrote: 1. Measure the volume of the JBL SRX815P plate amp (the part that sits inside of the cab) in cubic inches.
EXCEPT, this accounts for *volume* used by the amp, but it also destroys the proportions of the horn in that 2nd to last fold.
Rich4349
#55 Post by Rich4349 »
I follow your point, except you're going to run the amplified signal to a standard cabinet first, anyway, and S/P to the others, anyway, sooo...
For his idea you're running power from a nearby (hopefully) outlet, and an unamplified signal from the mixer etc to the first cabinet. I realize this isn't the optimal way, given ground loop hum, etc, so no need to :horse: any earlier points, but this guy seems hellbent on doing it, so let's give him all the rope he wants!
So Chris: how goes the relationship with the manufacturer you're contracting with? Get a unit price yet?
#56 Post by Bruce Weldy »
Rich4349 wrote: but this guy seems hellbent on doing it, so let's give him all the rope he wants!
thus my :mrgreen:
I did do some research on the amp for him.....I still would run no more than two cabs off that amp. And you still have the problem of all the proprietary DSP that is most likely in that JBL amp. Most likely has a set EQ curve for that particular full-range box - might not be ideal for a BFM sub.
If you are going to go the powered route, get an amp that just produces clean power without the extra baggage of one coming out of an off-the-shelf speaker.
David Raehn
#57 Post by David Raehn »
Of course, Sommer Cable makes combo power-signal cabling:
http://shop.sommercable.com/en/Cables/B ... 051-1.html
so that will level the playing field.... :roll:
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
#58 Post by Bruce Weldy »
David Raehn wrote:Of course, Sommer Cable makes combo power-signal cabling:
Yikes! Fine for lights.....not for audio. Don't want that power cable to run parallel to the signal cable for long of a distance that close together. While we all run our power and snake next to each other - at least they are in separate jackets and not living in that close a proximity.
David Raehn
#59 Post by David Raehn »
They say it's rated for AES/EBU, DMX and balanced audio....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
#60 Post by Bruce Weldy »
David Raehn wrote:They say it's rated for AES/EBU, DMX and balanced audio....
Yeah, but do you really want a power cable running right up next to your signal cable? One of the first things I remember learning in audio was to try and cross power and signal at right angles when possible and try to stay away from then running alongside. May be an old wive's tale.....but, it would make sense that there could be some issues with hum interference running analog audio.
