Page 4 of 4
Re: Looking for an amp recommendation
Posted: Mon Aug 22, 2016 11:26 am
by zpro
Bump.
Nobody can give me some advice on this?
Thanks,
Z
Posted: Mon Aug 22, 2016 3:43 pm
by Grant Bunter
zpro wrote:Bump.
Thanks,
Z
Do you mean adding bluetooth?
Because it's adding more to the chain, I would leave it out initially.
Get everything else sorted first...
Posted: Tue Aug 23, 2016 7:30 am
by zpro
Thanks Grant Bunter, yes I was referring to the fact that I still don't know whether it is possible to use a digital bluetooth receiver with the minidsp and if so, which one.
I want to have bluetooth setup as soon as possible because the minidsp will be located in a location that is not useable for a wired connection (i.e. usb)
If anyone can direct me I would truly appreciate it!
Z
Posted: Tue Aug 23, 2016 8:16 am
by Chris_Allen
What version of Bluetooth does your Macbook support?
I know the later versions were considerably better and not having to compress the audio anywhere near as much. I would get the latest BT version (4.0?) on your receiver then at least you don't have to upgrade it should you end up getting a 4.0 transmitter.
Posted: Wed Aug 24, 2016 7:22 am
by zpro
It does have bluetooth 4.0 already built in.
Any models you would recommend specifically for use in my scenario?
Many thanks!
Z
Posted: Thu Aug 25, 2016 9:57 am
by zpro
Decided to go with apple's airport express A1392. Awesome little device! Also avoids the problem of bluetooth compression.
It outputs digital using a combined mini TOSLINK and conventional 3.5mm port, both in one...
Thanks!
