SLA Pro driver question
kenkenni
Re: SLA Pro driver question
#46 Post by kenkenni »
Rain wouldn't let me work outside the last couple of days so I made due by assembling the cross-overs.
Here is a group photo. I ran out of terminal barrier before I could finish the last one.
Here is a better shot. Does everything look in order?
#47 Post by Tom Smit »
Good reuse of wood! :clap:
kenkenni
#48 Post by kenkenni »
Yeah, Thanks! I get plenty more from all the mis-cuts I made so far. I am still learning as I go. Anyone got any good tips for cutting
the tweeter array for those of us without a saw table, that will make the task easy. I will figure it out as usual but any good advice helps.
67baja
#49 Post by 67baja »
kenkenni wrote: Anyone got any good tips for cutting
Do you have a miter saw? I have cut all my piezo with a miter saw.
67baja
#50 Post by 67baja »
Or maybe a grinder with a cutoff wheel? That would work too.
kenkenni
#51 Post by kenkenni »
No Mitre Saw yet either, I,m afraid. I have been looking at them in Lowes though. Waiting for some kind of sale
on them. So I'm building with only my circular saw, jig saw, and router at the moment.
#52 Post by Tom Smit »
One could make a jig for the tweet cutting, place the circular saw upside down on a board and flip the board around so that it becomes a table saw.
https://www.google.ca/search?client=ubu ... 8QfA6auwBg
#53 Post by DJPhatman »
Over-width saw sled. Clamp the piezo body, with no element mounted, to the underside of the saw sled, then flip the sled right side up and clamp it to a stable work surface. Time consuming, but easy to do.
kenkenni
#54 Post by kenkenni »
I never thought of that before. That just may be the answer. I'll come up with something and then share it you.
#55 Post by Bill Fitzmaurice »
DJPhatman wrote:Over-width saw sled. Clamp the piezo body, with no element mounted, to the underside of the saw sled
+1, but not with a clamp. Make the sled with a 45 degree cutting edge. Screw a stop board to the underside of the sled to set the distance from the outer edge of the piezos to the cut line, screw all of the piezo horns to the bottom of the sled against the stop board, and cut them all with one pass. Make sure you use a fine tooth plywood blade or an abrasive blade.
ripNdeb
#56 Post by ripNdeb »
and carefully sand off the excess - can't think of the word - that doesn't belong there. So they're all the same length/width as each other.
Flashing, that's the word :)
kenkenni
#57 Post by kenkenni »
Some good ideas there guys. I'm looking into them as we speak.
#58 Post by Tom Smit »
[quote="kenkenni"
[/quote]
Everything looks to be in order. :clap:
kenkenni
#59 Post by kenkenni »
Using some of you guys ideas, this is how my brain translated them to this odd little rig here.
Using a square piece of scrap board I laid 4 tweeters on top and measured the required distance
on each end. The first four have been cut using a plunge blade on my oscillating tool. The cut lines
that are left is now the template for cutting the next four.
Here is just a better angle of the four already cut.
Here I am lining the tweeters up square and even.
I then secured them with screws so they would not move during the plunge cut.
I then flip over the board and secure it.
With my plunge blade up agaisnt the botttom lines of the cut I proceed to carefully plunge through.
After the plunge cuts have been made.
Now time to switch the plunge blade for the sander and clean up the edges of the tweeters.
The cut tweeters are now clean and smoothed up for the next process.
Here I'm using the same concept to do the four ends of the tweeter array.
Laying the tweets out here in preparation for joining.
Joining the tweeter array up with Black ABS Cement.
And here is the completed array. Done in about three hours.
I do have another question. The pipe cement I used was called Oatey Medium Black ABS Cement. Bought at Home Depot is this the correct type of pipe cement?
There were so many kinds, till I just bought what sounded close to what I needed. It appears to be holding up so far, though there is a little flex in the whole array,
but not enough where it can break. I am going to let it sit at least a day and then see If it is strong enough.
#60 Post by Tom Smit »
Good work! You accomplished it! :clap:
That glue will work fine. The array will be flimsy, just handle with care.
