Page 4 of 4
				Re: Anikun's THT LS Build
				Posted: Wed Jan 14, 2015 7:49 pm
				by anikun07
				Good plan. I made a small cabinet to hold 3D glasses do they wouldn't collect dust sheath not in use. I love how the routered plies look in a curve for an edge.  That I actually did finish, oddly enough.
				Posted: Thu Jan 15, 2015 2:44 am
				bitSmasher wrote:
Slowly, slowly, getting the decor to have a running theme of plywood grain... so when I finally make a TTLS and leave it unpainted, the girlfriend can't complain that it doesn't match the room!
Sneaky.
				Posted: Fri Jan 16, 2015 7:37 pm
				by asarose247
				wrt to pointing up
trying to follow the plans,  and the loading spec of 18 inches,
and for easy of movement/placement
I bough 2 of the smaller furniture moving  dollys from Harbor Freight,
reconfigured them together  for width and length and then added a bit of plywood on top to get the mouth a bit closer to the ceiling
tho being in a corner adds to the loading equation . ., the math for that is beyond me . . .
then see what REW shows what you did
if you have audyssey xt 32, you're moving up a notch or 2 or
a minidsp 2 x 4 unbalanced, maybe even better
but remember the design rolls off  from 20 hz rather drastically  but you should be good for about 99-98% of ALL media out there
turn it up
I have 3 THTLP's,  its all good . . .
