Anikun's THT LS Build
Re: Anikun's THT LS Build
Good plan. I made a small cabinet to hold 3D glasses do they wouldn't collect dust sheath not in use. I love how the routered plies look in a curve for an edge. That I actually did finish, oddly enough.
Sneaky.bitSmasher wrote: Slowly, slowly, getting the decor to have a running theme of plywood grain... so when I finally make a TTLS and leave it unpainted, the girlfriend can't complain that it doesn't match the room!
asarose247
wrt to pointing up
trying to follow the plans, and the loading spec of 18 inches,
and for easy of movement/placement
I bough 2 of the smaller furniture moving dollys from Harbor Freight,
reconfigured them together for width and length and then added a bit of plywood on top to get the mouth a bit closer to the ceiling
tho being in a corner adds to the loading equation . ., the math for that is beyond me . . .
then see what REW shows what you did
if you have audyssey xt 32, you're moving up a notch or 2 or
a minidsp 2 x 4 unbalanced, maybe even better
but remember the design rolls off from 20 hz rather drastically but you should be good for about 99-98% of ALL media out there
turn it up
I have 3 THTLP's, its all good . . .
turn it up
