Page 4 of 4
				Re: First build T39 16in wide - bp102
				Posted: Mon Feb 10, 2014 7:46 pm
				by Saddle
				So I'm finally back at it. 9 weeks of not getting around to it because of a meniscus tear/breakdown in my right knee, and winter in general. .. Pictures to come.
Have a question about breaking in my BP-102.. actually the amp I'm going to use to drive it. I have a QSC USA1310 amp. Does it hurt this amp to run one side breaking in the BP-102 and nothing on the other side of the amp? I've read that Solid State amps aren't damaged if ran without a driver attached, but I've always been concerned about that..
So to answer my own question, I'll just attach a junk speaker and not drive that channel... duh..
				Posted: Tue Feb 11, 2014 12:03 am
				Saddle wrote:So I'm finally back at it. 9 weeks of not getting around to it because of a meniscus tear/breakdown in my right knee, and winter in general. .
Sorry to hear that.
Saddle wrote:Does it hurt this amp to run one side breaking in the BP-102 and nothing on the other side of the amp?
Not at all.
				Posted: Mon Feb 17, 2014 6:20 pm
				by Saddle
				Posted: Mon Feb 17, 2014 6:45 pm
				by Grant Bunter
				Nice tidy build so far, keep up the good work!
				Posted: Mon Feb 17, 2014 9:36 pm
				by Saddle
				Grant Bunter wrote:Nice tidy build so far, keep up the good work!
Thanks Grant. I hope I can put the last side on it tomorrow. It will be a while before I get to the level of building and equipment you have in your Light and Sound setup. Nice Facebook page too!
				Posted: Mon Feb 17, 2014 11:01 pm
				by Grant Bunter
				Nah it's all smoke and mirrors lol
With the cabs, paint hides a multitude of patches.
Lighting hides the rest!
				Posted: Thu Feb 20, 2014 3:04 pm
				by Saddle
				Well, got the rest done and the side put on. So I think I just had a "Welcome to my World" moment with bondo...
Gee... How could a golf ball size of that stuff make such a mess! I used two plastic bondo applicators just mixing it. I used a lot of hot mud in the past, but this is like 5 minute mud! Proper ventilation means outside in a stiff breeze!! I can still taste it. But, dang... it sure fills in the holes...
I think I could tape a house with PL and make less of a mess. Glad it does harden. Even gladder that I have a lot of 80 grit sandpaper. Smaller amount, and a smaller knife to apply it with next time.
Still stinks!
				Posted: Thu Feb 20, 2014 4:10 pm
				by Grant Bunter
				Saddle wrote:Well, got the rest done and the side put on. So I think I just had a "Welcome to my World" moment with bondo...
Gee... How could a golf ball size of that stuff make such a mess! I used two plastic bondo applicators just mixing in. I used a lot of hot mud in the past, but this is like 5 minute mud! Proper ventilation means outside in a stiff breeze!! I can still taste it. But, dang... it sure fills in the holes...
Still stinks!
Ha ha,
If your bondo is going off in 5 minutes, try just a little less hardener, and try not to overwork it when mixing. I get 7-10 minutes when I use it. Means I get at least one side and one top (or bottom) per mix and that's all filling screw holes...
				Posted: Thu Feb 20, 2014 9:14 pm
				by Saddle
				I used a little less hardener this time. Had more working time, and mixed it with a stick instead of the plastic paddle. Worked pretty well.
One quart is going to go a LONG way.. I'll have to find other uses for it other than this cab.
				Posted: Thu Feb 20, 2014 9:42 pm
				by djtrumptight
				Saddle wrote:I used a little less hardener this time. Had more working time, and mixed it with a stick instead of the plastic paddle. Worked pretty well.
Yeah,other uses like on your next cabs,there will be others lol.
				Posted: Fri Feb 21, 2014 4:49 pm
				by DJPhatman
				djtrumptight wrote:Yeah,other uses like on your next cabs,there will be others lol.
Says the man who built some in Michigan's record-breaking winter, OUTSIDE (
You, good sir, win the CRAZY PHAT award!
 I've been-->
				Posted: Tue May 27, 2014 5:45 am
				by djtrumptight
				Wow,im just seeing this lol.
