Page 4 of 5
				Re: Table Tuba 18" wide build
				Posted: Wed Mar 27, 2013 7:49 am
				by zvipster
				shawn_g wrote:zvipster wrote:
Can you describe what you've got going on in these pictures? Unless the plans have changed, I don't remember anything like this in the Table Tuba plans that I have.
Sure!
The  panel with the hurricane nuts are the one that is being permanently installed in the Tabletuba.
The on with the rubber gaskets are the one I will be screwing the driver to an then fasten that panel to the Baffle.
				Posted: Wed Mar 27, 2013 8:10 am
				by shawn_g
				zvipster wrote:
Sure!
That makes sense. Is that a new addition in the plans or is that something that you came up with? I can see how it would make changing to a different driver easier since they often have slightly different bolt patterns.
				Posted: Wed Mar 27, 2013 8:11 am
				by Michael Ewald Hansen
Sure!
That will probably not work. Bill added the driver spacer option in the last update so you could glue the spacer to the baffle and then have 24mm of wood to screw into. That way you didnt have to use tnuts/hurricane nuts.. You will likely have a problem with not being able to tighten down the driver properly when only mounting it to 12mm of material - especially the GTO804 with its extremely rugged gasket.
				Posted: Wed Mar 27, 2013 9:16 am
				by zvipster
				Well, I will try and see if it can be done.
I plan on using some rubber gasket, the same as on the wood panel, between the hard rubber gasket and the wood.
That way I should get some nice compression, without having to dig to deep in the wood.
If not then I will have a problem
				Posted: Wed Mar 27, 2013 9:18 am
				by zvipster
				This is one of the places where I misunderstood the plans.
I actually thought I was supposed to do it this way.
Even more since I've seen other builds where the spacer is held in place by Hurricane nuts and bolts.
But we'll see either this evening or tomorrow when the glue is dry.
				Posted: Wed Mar 27, 2013 9:54 am
				zvipster wrote:T
In every build I've ever seen, the spacer is glued in and the nuts and bolts hold the speaker.  The spacer is essentially part of the baffle, not like a giant washer that can be taken on and off.
				Posted: Wed Mar 27, 2013 10:08 am
				by zvipster
				Posted: Thu Mar 28, 2013 5:31 am
				by zvipster
				It is done
				Posted: Thu Mar 28, 2013 6:12 am
				by shawn_g
				zvipster wrote:It is done
Not until you post some pictures.
Have you had a chance to try it out yet?
				Posted: Thu Mar 28, 2013 6:19 am
				by zvipster
				While I resize pictures and upload, all you in here with Tubas, take a listen to this track!
http://www.youtube.com/watch?v=r0EVEXX9 ... w&index=37
I thought I knew that track well, altso the bass part of it.
The deep end is astonishing
				Posted: Thu Mar 28, 2013 6:29 am
				by zvipster
				So it is now done!
Havent pu any finishing touches on it yet, and don't know if I will be doing that either.
Too lazy to take it downstairs again when I can watch another movie
				Posted: Thu Mar 28, 2013 6:30 am
				by zvipster
				Michael Ewald Hansen wrote:zvipster wrote:
Sure!
Btw, this worked flawlessly!
				Posted: Thu Mar 28, 2013 7:07 am
				by shawn_g
				Looks great! Nice work.
				Posted: Thu Mar 28, 2013 7:23 am
				by zvipster
Sure!
Apparently it was something a came up with
I should have made the hole in the baffle ready for a 10" instead, then I could have the possibility to change between drivers
				Posted: Thu Mar 28, 2013 8:02 am
				by zvipster
				How much voltage can this driver take?? (JBL GTO804)
I've had it up to 20v, that gave me a headache, so I turned it down and during listening it peaks at about 2.5v
