Page 4 of 4
Re: 2 Jack 12's - first time cab builder
Posted: Fri Sep 28, 2012 6:47 am
by LelandCrooks
Great thread. Great build.
Posted: Fri Sep 28, 2012 1:34 pm
by James Champer
Bruce Weldy wrote:AntonZ wrote:I hope you are going to build plenty more cabs and post build threads on all of them. Your writing about the process makes a very enjoyable read
thanks for sharing.
But, you've got to figure out how to post bigger pictures!
Thanks guys. And..
But I can! But I can make them bigger! (all updated now- 2015)
Hell, I used to do graphics for a living, I was just trying to save bandwidth for those challenged.
I'll make 'em bigger for the beauty shots I promise
Posted: Sat Jun 20, 2015 2:50 pm
by James Champer
Well whaddy'a know. Here it is, more than two years later and I finally found some extra shots of these, my first build. (sorry, was in the bathroom)
Better late than never eh? And don't hold your breath here, the shots would have been better but I can still hear the laughter of the Olan Mills staff when I brought them in an began posing them. (It's a painful memory and I don't like to talk about it)
So we'll all have to be content with a garage shot on a cheap plastic table.
In all their original glory:
So there you have it- CLOSURE!
*whew*
And I still don't care what crafty thinks.
ONWARD!
Posted: Wed Jul 08, 2015 6:26 pm
by DJ Nada
Outstanding thread 10/10
Posted: Fri Jul 24, 2015 2:23 pm
by thekl0wn
Great looking work! Especially on a first build.
What part of Indy are you in?
Posted: Sat Jul 25, 2015 5:55 am
by James Champer
Thanks!
SE Indianapolis is where I hang my hat
Posted: Sat Jul 25, 2015 1:59 pm
by 67baja
I like the handles you used on those. Where did you get them? My Jack has the heavy spring loaded steel handles. Yours look very clean.
Posted: Sun Jul 26, 2015 7:07 am
by LelandCrooks
Posted: Mon Jul 27, 2015 9:28 am
by James Champer
What he said
And yes, they work great on the Jack. Low profile, good carry spot, comfortable. I like them so much I put them on both pair of Jacks I've built for myself, and suggest them to my clients.
Posted: Mon Feb 06, 2017 2:01 am
by ybiteykin
About to start my own Jack 12 build and will be referring to this thread regularly, both for technical and comedic reference.
One question - which kit/which crossovers did you get from speakerhardware? (I'm assuming you got a kit, based on the BF badge ... which I totally dig, by the way)
Struggling to pick the correct xovers. Their website is not very good in the xover section, descriptions are lacking.
I have plenty of electronics experience, would prefer to save a few $ and wire my own, instead of buying the prebuilt. Frankly I don't like the prebuilt xover boards they offer, just need to make sure I'm choosing the right components.
Here's what I've come up with so far. Any help would be greatly appreciated.
LP filter:
https://www.speakerhardware.com/low-pas ... 00watt.php
HP filter:
https://www.speakerhardware.com/high-pa ... -array.php
Fairly certain on my LP filter choice, it'll be paired with the 8ohm Kappalite 3012HO
The HP filter choice is a bit uncertain. I plan to build the 16x melded array.
Posted: Mon Feb 06, 2017 7:39 am
There's nothing lacking in the plans.
Posted: Mon Feb 06, 2017 7:17 pm
by ybiteykin
Bill Fitzmaurice wrote: There's nothing lacking in the plans.
Plans are very clear. It's trying to source the xover parts kit from speakerhardware.com that's my problem.
Their website is not at all descriptive in terms of which components you are getting in their crossover kits.
I may source the parts elsewhere, there are plenty of other suppliers and these are pretty common crossover networks... or I may just spend the $10 on the '2k High Pass 500w Crossover Piezo ' and see what arrives.
Also, I need to do some studying on the theory, will save my questions until after.
Posted: Mon Feb 06, 2017 10:31 pm
ybiteykin wrote:Bill Fitzmaurice wrote: There's nothing lacking in the plans.
The kits have everything you need to build the crossovers. Trying to source those parts is a real PITA. I blew up a crossover once and finding parts was impossible - finally just ordered 'em from Leland....much easier.
Posted: Tue Feb 07, 2017 12:31 am
by David Raehn
When you order from speakerhardware.com all you have to do is select the crossover for the design. They will make sure all the required components are bagged up for you. No ordeal at all.....
Posted: Wed Feb 08, 2017 8:06 am
by LelandCrooks
I don't understand. Do you want a parts breakdown in the description? If so, that's copyrighted by Bill. The name is exactly what it is, a high pass at 2k for piezos. Every piezo cab except for the SLA pro uses that high pass filter. Did you click the tab "specifications"? It lists every cab it fits.
