JBL 804 vs TangBand 740P
N.Webber
Re: JBL 804 vs TangBand 740P
#46 Post by N.Webber »
And here are the results…
This was the setup of the two ATs, placed side by side in a 'dual afterburner configuration' in a Citroen C3…:
The test rig was set on the passenger's seat:
The measurement microphone's location:
The comparison was done with all conditions, levels and other settings throughout the system equal and untouched.
Only the selector switch was used to alternate between the cabs.
This is the combined plot of all 7 test runs, the different traces explained below.
Here is the full spectrum view:
And here a zoomed view of the low end:
First, the cabs ware pushed all the way forward against the backs of the front seats, leaving about 40cm (16") from the horn mouth to the back door, like this:
In this position I first tested the response with the back door open. The (lower) green trace is of the JBL and the purple trace is of the TB.
I then closed the back door. The yellow trace is of the JBL and the orange trace is the TB's.
Following, I moved the cabs all the way to the back, with the horn mouth right against the (closed) back door, like this:
The light blue trace is of the JBL and the (top) green trace is of the TB.
I then returned the car to its 'normal' configuration, and placed the JBL loaded AT in the trunk, like so:
The top blue trace is of this configuration.
I then took some power and SPL readings. This is 40Hz at 1w:
This is 40Hz at 100w:
And this is 40Hz at 150w:
Summery;
I played a variety of tracks, constantly alternating between the cabs, and to my humble ears there wasn't any noticeable difference between them.
Both sounded exactly the same and just great. Both supplied a nice and amazing low end (down to 30Hz and lower… I know, small cabin…)
In view of these listening tests, as well as the measured plots, I think it is correct to conclude that both the JBL and the TB are suitable and perform equally (well) in the AT.
It definitely looks like the small variations in the JBL's T/S parameters (compared to the recommended TB) are probably not off enough
to spoil the amazing performance of the AT design.
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
bassmonster
#47 Post by bassmonster »
:clap: :clap: :clap:
Thanks for doing this! This should be a sticky too.
Glad the JBL is up there with the rest.
Ryan A
#48 Post by Ryan A »
Thanks so much for putting in the time and effort to do this...it is all so detailed yet easy to follow. Good work.
shawn_g
#49 Post by shawn_g »
:clap: Awesome test results. I'm anxious to hear what the other car audio guys think of the setup.
Michael Ewald Hansen
#50 Post by Michael Ewald Hansen »
Nice tests! Just a small correction.. Since atleast the JBL is 4ohm (dont know how the horn loading adds to this calculation) 2.83v is 2w.. (2.83*2.83)/4 = 2 watt :) So the first picture showing 106db is actually at 2w and the rest is different too..
Other than that, I love the ingenuity of the test rig :)
Authorized Builder - Denmark
#51 Post by Radian »
Very nice!! :clap:
bassmonster
#52 Post by bassmonster »
Is that Pyle crossover any good? What model is it? Might have to pick me up one of those...
N.Webber
#53 Post by N.Webber »
Michael Ewald Hansen wrote:Nice tests! Just a small correction.. Since atleast the JBL is 4ohm (dont know how the horn loading adds to this calculation) 2.83v is 2w.. (2.83*2.83)/4 = 2 watt :) So the first picture showing 106db is actually at 2w and the rest is different too..
You are right regarding the added impedance of the horn, but the truth is some ware in between…
Indeed I calculated the voltage according to the (total) impedance being 8 ohms. Not sure where I got that figure from though?... :?
Here is an impedance plot (WT3) I once did to my TAT (in the van) and at 40Hz it actually reads about 12 ohms!:
That would suggest even lower power needed to achieve those SPL levels. I'll run the WT3 on these ATs and see how they really measure.
bassmonster wrote:Is that Pyle crossover any good? What model is it? Might have to pick me up one of those...
No! I would not recommend it. I found some irritating issues with it...
The XO frequency controls don’t match the panel markings and also the level controls are not linear in their behavior.
I took this piece because I needed a basic external XO. Most 4 channel car amplifiers have some type of XO control built in,
so you're basically getting the XO for free.
If you're looking for a really good and versatile XO, I would recommend the MiniDSP route… http://www.minidsp.com/
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
#54 Post by Bill Fitzmaurice »
N.Webber wrote: Here is an impedance plot (WT3) I once did to my TAT (in the van) and at 40Hz it actually reads about 12 ohms!:
A ragged plot with high peaks is normal. You quantify nominal impedance by the minimum, which is about 5 ohms in the plot. That's equivalent to a 7 to 8 ohm nominal.
#55 Post by Radian »
N.Webber wrote:That would suggest even lower power needed to achieve those SPL levels.
8 Ohms checks with me. But...are you sure that second pic (showing 20.79V) is 100W? I'm confused. Cross-checking the reading on the SPL meter against the voltage reading, the math appears to be more like ~50W and then 77W (good for the extra 2 dB SPL) for the last one. :confused:
#56 Post by CoronaOperator »
Great test results. Did you get a chance to parallel both cabs and listen to some dub-step with both cabs at wide open throttle, doors closed? :chainsaw:
bassmonster
#57 Post by bassmonster »
You'd get in the high 120's/low 130's with that, I expect.
#58 Post by Bill Fitzmaurice »
That brings up the point that you shouldn't measure specific frequencies at specific voltages to estimate power. It's irrelevant, since in operation the amp will deliver the same voltage at all frequencies, irrespective of impedance. True that the current delivery and therefore power drops as impedance increases, but don't make too much of that, being just frosting on the cake as it were. Besides, all alignments have impedance peaks.
#59 Post by Radian »
Bill Fitzmaurice wrote: It's irrelevant, since in operation the amp will deliver the same voltage at all frequencies, irrespective of impedance.
If relating SPL output and voltage through the use of Ohm's law and the Decibel equations is irrelevant, what other method do you suggest the technician use to predict their relationship out in the field?
I know of no other way to get from one value to the other without calculating power at least once, through the formulas. I understand there are always grey areas in real applications, but somewhere a line has to be drawn in the sand so the pro can say, "Yes, I can meet this spec." with confidence. :|
#60 Post by Bill Fitzmaurice »
Radian wrote: If relating SPL output and voltage through the use of Ohm's law and the Decibel equations is irrelevant, what other method do you suggest the technician use to predict their relationship out in the field?
I didn't say that. I said power is irrelevant. Voltage swing is what should be considered.
