Another newbie with an interesting quest
Re: Another newbie with an interesting quest
#31 Post by Bill Fitzmaurice »
DJPhatman wrote:After listening to a few you-tube videos of performances, I think that you might need to stay away from piezos. If you use any distortion effects, IIRC, piezos don't like it at all. Tim A and Bill should chime in on this, but an O12 or an O15 will be your best choices for a full-range cabinet. If you play a lot of the really low bass, go O15.
+1. No tweeters with distortion. O12 or 15 with a mid driver only.
EricK
#32 Post by EricK »
I think we're converging on the best solution from BFM. I think the O12 TallBoy would be my choice. The next question is, I already own a JBL 2206 12" driver. Would it work in an O12? Their T/S params seem similar enough but I don't anything about the horn design. Here are the T/S of both:
Delta 12LFA:
fs: 51 Hz
Re: 6.06 ohms
Le: 1.45mH
Qes: .51
Qms: 7.28
Qts: .47
Vas 67.9 Liters/2.4cu. ft.
Xmax: 4.8mm
BL: 14.1 T-M
Sd: .05067m2
JBL 2206H:
fs: 52 Hz
Re: 5.3 ohms
Le: 1.5 mH
Qes: 0.34
Qms: 4.5
Qts: 0.32
Vas: 62 l(2.2 ft3)
Xmax: 7.5 mm (0.30 in)
B1 Factor: 18.1 N/A(H)
SD: 0.055 m2 (84.7 in2)
Are there any other choices for the mid driver?
Thanks,
-Eric
Sydney
2206
#33 Post by Sydney »
Eric:
I Had a stick question, but I think I lost the link I was referencing,
Oh well, If I find it I ask.
* Edit - Never mind, found the answer.
#34 Post by Bill Fitzmaurice »
The 2206 is fine, otherwise stick with the plans.
