DR200 and T30 First Impressions
Re: DR200 and T30 First Impressions
I would also vote for OT12's. They are my favorite mostly because of an easier quicker build, not to mention the fact that they will crossover at 100 Hz unlike the DR200 that crosses at 120HZ. This can be an important factor because of integration with subs. Subs can begin to become directional at 120 Hz.
I was initially hesitant about the DR200s because of the higher crossover, but from the response charts it appears that if you eq them flat you can cross them over around 100hz without much loss at all. (It also works out fine for me, as most of my gigs are electronic music and I generally find myself adding a slight dip from 80-125hz to remove some of the muddiness from the bass...)BillyG wrote:I would also vote for OT12's. They are my favorite mostly because of an easier quicker build, not to mention the fact that they will crossover at 100 Hz unlike the DR200 that crosses at 120HZ. This can be an important factor because of integration with subs. Subs can begin to become directional at 120 Hz.
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
4 DR250s
2 ATs
