Cutting piezos and not your fingers.
mlkras
Re: Cutting piezos and not your fingers.
#31 Post by mlkras »
DaveK wrote:Thanks. I hesitate to talk about that jig in a thread about saw safety, but I'm very happy with it. The reason I hesitate is that I hold the tweeters in the jig with my fingers as I slide it across the blade. That puts my fingers within 2 inches of the blade. Needless to say, I'm very careful.
DaveK, that is a very nice jig. I think that Rockler sells some lever locking hold down clamps intended to secure work on a bench that perhaps you could use to hold the tweeters in place while you are cutting. The top of the clamp would fit on the back of the tweeter.
bzb
#32 Post by bzb »
I'm confused on the lug thing. In the plans, it doesn't reference any issue with the lugs getting in the way, and certainly doesn't appear that they get in the way in the pictures of the glue-up. Am I missing something here?
All tweeters are cut on the lug end, so when assembled the lugs all face each other.
^^ has this changed? It says this for both my OT12 and DR plans...
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
#33 Post by DJPhatman »
Some of the builders have taken to "reversing" every other piezo in an array, meaning every other one has the "lug" pointing in the opposite direction.
bzb
#34 Post by bzb »
Still not seeing how the lugs would get in the way, even when cut on the other side. Maybe I'll understand better when my piezos arrive.
Bobby Shively
#35 Post by LelandCrooks »
bzb wrote:Still not seeing how the lugs would get in the way, even when cut on the other side. Maybe I'll understand better when my piezos arrive.
Build a DR array, and you'll understand
David Carter
#36 Post by David Carter »
+1!
Dave
- 2 x Titan 39 (BP102 - 14"W)
bzb
#37 Post by bzb »
Gotcha. I only looked at the DR200 plans.
Bobby Shively
bzb
#38 Post by bzb »
OK one last question on the 45 degree cuts... What's the measurement from the right edge to the short edge of the 45? I'm pretty sure I have the jig correct... but I don't want to destroy two piezos to find out!
Edit: OK, it's in the OT12 plans.
Can I do this to myself?
:iitp:
Bobby Shively
#39 Post by LelandCrooks »
bzb wrote:Can I do this to myself?
:iitp:
Only til the hair starts to grow on your palms, or your vision starts to blur.
bzb
#40 Post by bzb »
:iitp:
Damn, I'm already past the limit. :lol:
Bobby Shively
slotech88
#41 Post by slotech88 »
hartley can you make a plan of that jig or at least the dimensions.
thanks
Harley
#42 Post by Harley »
slotech88 wrote:hartley can you make a plan of that jig or at least the dimensions.
thanks
Capital H,
No T,
a question mark, and
a please; would grease the wheels, :cop:
BUT,
That jig is made to my table saw and the bits and pieces I had available. It would be different for anyone else's.
The dimensions are governed by the piezo cut dimensions and the size of the piezos in any case.
The various camera angles provide you all the detail you need really.
WB
#43 Post by WB »
thanks
Capital H,
No T,
BUT,
Plus one to all of the above.
bzb
#44 Post by bzb »
Is War Office Whipping Boy acceptable?
If you need to go off plans, Bill offers the piezo jig in the panel jig set for two bucks.
http://billfitzmaurice.net/PanelJig.html
Bobby Shively
Harley
#45 Post by Harley »
bzb wrote:Is War Office Whipping Boy acceptable?
Only with leather boots and net stockings on :mrgreen:
