Page 3 of 21
				Re: Introducing SPL Chart
				Posted: Mon Apr 06, 2009 3:10 pm
				by Chris_Allen
				TomS, I edited your post for the newer format of the spl tag - but didn't alter your frequency range statement.
				Posted: Mon Apr 06, 2009 11:41 pm
				Thanks Chris_Allen. And I made a mistake in reading the chart...shoulda' said 38hz
I was looking at the chart with all the T48s, and zoomed it in on my moniter.....I just got lost in all the lines!
				Posted: Tue Apr 07, 2009 1:29 am
				by Chris_Allen
				You can always edit your post and chart
				Posted: Tue May 19, 2009 4:15 am
				by Futte
				Will the new Jack also be added?
Thanks
				Posted: Tue May 19, 2009 6:06 am
				by Chris_Allen
				I'm sampled them already but the calibration was off so I have to do them again.
They'll be up by tonight!
				Posted: Tue May 19, 2009 6:34 am
				by Futte
				Great - Thanks
				Posted: Tue May 19, 2009 4:16 pm
				by Chris_Allen
				Code: Select all
[spl]J110,J110ASD1001,J110NSD2005,J110M12,J210F12&dbmin=80&dbmax=115[/spl]
Code: Select all
[spl]J110M12,O105D2510&dbmin=80&dbmax=110[/spl]
Code: Select all
[spl]J110ASD1001,OT12P&dbmin=80&dbmax=110[/spl]
Code: Select all
[spl]J210F12,DR250,O12&dbmin=80&dbmax=110[/spl]
				Posted: Tue May 19, 2009 5:56 pm
				by DaveK
				Bass players, check this out!  Jack210 == Omni 15 (maybe with the help of a little EQ to flatten that dip and hump at 1500-3000
				Posted: Tue May 19, 2009 7:38 pm
				by Harley
				DaveK wrote:Bass players, check this out!  Jack210 == Omni 15 (maybe with the help of a little EQ to flatten that dip and hump at 1500-3000
Well, I've just built an O15TB and could probably use the DLII2510's from my current O10 and build a J210 and compare.  That would be real interesting after seeing that chart.
				Posted: Tue May 19, 2009 8:58 pm
				by dug dog
				Harley wrote:Well, I've just built an O15TB and could probably use the DLII2510's from my current O10 and build a J210 and compare.  That would be real interesting after seeing that chart.
Yes please.
				Posted: Tue May 19, 2009 9:38 pm
-1. Jack 210 is 4 ohms, O15 is 8. Jack 210 has 294cc displacement, O15 has 846cc. SPL charts alone do not tell the whole story. And there's still no such thing as a free lunch.
				Posted: Wed May 20, 2009 12:02 am
				by DaveK
				Oops, forgot about the impedence difference.  Both charts are 2.83V, so lets say I connect up my bass amp that puts out a max of 45V.  Both cabs are still producing the same SPL, right?  The difference shows up when I connect my bass amp that puts out 60V.  The Omni 15 is now 3dB louder and the Jack 210 has fried drivers.
Are there other differences besides 3dB more max output?
				Posted: Wed May 20, 2009 8:17 am
				DaveK wrote: lets say I connect up my bass amp that puts out a max of 45V.  Both cabs are still producing the same SPL, right??
Wrong. You've blown the 2510s from over-excursion, so Jack's output is zero. You would have heard the 2510s complaining back around 30v, but since you ignored their plaintive cries they're now toast. RIP.
				Posted: Wed May 20, 2009 10:05 pm
				by DaveK
				45V into 4 ohms = 500W, which is the thermal rating of 2x 2510.  Do they hit Xlim at lower power than that?
				Posted: Thu May 21, 2009 8:01 am
				DaveK wrote:45V into 4 ohms = 500W, which is the thermal rating of 2x 2510.  Do they hit Xlim at lower power than that?
Yes. Thermal ratings in and of themselves are as tits to a bull.
