Speakerhardware.com
djtecthreat
Re: Speakerhardware.com
Some aluminum (solid, or anodized) plates that are laser etched (i do this a lot) would be sweet.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
Sounds like a new side business for you, then!djtecthreat wrote:Some aluminum (solid, or anodized) plates that are laser etched (i do this a lot) would be sweet.
Re Bfm Name Plates.
I addition to the above formal logo, I reckon it would be good to create a separate "Build Plate" to also detail each of the drivers installed and the build date.
Any ideas??
Cheers from a wet and windy New Zealand
David
Any ideas??
David
- Scott Brochu
Are you talking about the little name plates that are on some trophies?
cause can't you go to a place where trophies are sold and have some made up and you put them on the cab?
Just a thought.
Just a thought.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Speaking Heresy here.
18's are on sale. Limited quantities, 20% off. I know there are still a few of you out there running 18's instead of a tuba/titan like you should be.
http://www.speakerhardware.com/products.php?cat=120
bgavin
Link to Magnum Sub
The 4018LF is a great driver for a direct radiator for electric bass.
The link above is the one I built for my daughter's bassist (http://www.aroarah.com).
I fashioned it after her Eden D410-XLT for appearances.
In the Flat alignment, 4018LF hits Xmax limits at 370w and 53 Hz.
The down side is weight. VERY heavy.
Given my 'druthers, the O15TB is what I 'druther build.
Lelands the hookup.
The only way I'd be able to afford, and get cabs done on schedule.
damn fine sounding melded arrays also.
-More to come!
-More to come!
The copy is off, it says for all single piezo drivers, it's good for all piezo applications, singly or arrayed.LelandCrooks wrote:By popular demand. http://www.speakerhardware.com/2k_lphp_ ... mp500w.php
More to come pretty soon.
Edited, thanks. My familiarity with this stuff gets in the way of descriptions. It's for 8 ohm single woofer cabs. I haven't done the dual driver version yet.
Where the piezo array is concerned it's the same.LelandCrooks wrote:Edited, thanks. My familiarity with this stuff gets in the way of descriptions. It's for 8 ohm single woofer cabs. I haven't done the dual driver version yet.
djtecthreat
How about a pre-built crossover for compression cabs?
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
Done. Sent two prototypes to a Les a few days ago. It BARELY fits on the board. I forgot to take pics. I'll get it on the site in the next couple of days.
djtecthreat
Nice!
"Ask and ye shall receive" indeed.
Thanks Leland!!
Thanks Leland!!
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
-Building-
8 More T48's
-Built-
4 SLA Pro's
Took a while, but I finally found the right thing for bumper guard.
http://www.speakerhardware.com/cab_bump ... 1968bk.php
Those crossovers are back in prototype. Les's are correct, but I need to rework options before I put them on the site.djtecthreat wrote:"Ask and ye shall receive" indeed.
