Pix are still sideways in attachment thumbnails but not once clicked on.
viewtopic.php?p=292617#p292617
On other forums I can copy paste pix directly into the post window. Is that possible here, might simplify the attachment process.
Forum Maintenance: 14th September 2022
CarterKraft
Re: Forum Maintenance: 14th September 2022
Weldon Carter
The pix are sideways because you're holding your phone upright when taking the picture. Hold it horizontal.
- Chris_Allen
You can drag and drop into the 'Post a reply' box if that helps.CarterKraft wrote: ↑Thu Oct 06, 2022 10:10 pm On other forums I can copy paste pix directly into the post window. Is that possible here, might simplify the attachment process.
- Chris_Allen
I need to check the preview config to see if there is an auto rotate option.CarterKraft wrote: ↑Thu Oct 06, 2022 10:10 pm Pix are still sideways in attachment thumbnails but not once clicked on.
CarterKraft
I see, more to learn.Chris_Allen wrote: ↑Sat Oct 08, 2022 1:44 pmYou can drag and drop into the 'Post a reply' box if that helps.CarterKraft wrote: ↑Thu Oct 06, 2022 10:10 pm On other forums I can copy paste pix directly into the post window. Is that possible here, might simplify the attachment process.
Weldon Carter
CarterKraft
Bill Fitzmaurice wrote: ↑Fri Oct 07, 2022 12:55 pm The pix are sideways because you're holding your phone upright when taking the picture. Hold it horizontal.
I will give that a shot.
Weldon Carter
