Simplexx 212 build w/ Pics
Electric Wisdom
#31 Post by Electric Wisdom »
Tom Smit wrote: Sat Mar 03, 2018 7:33 pm Everything on the Speakerhardware site is legit, priced right, and of the right specs. The owner is a forum member, even once was a moderator(until his business got real busy with us forum members).
Another site that is more local is https://qcomponents.ca/ (Waterloo, Ontario)
With a little digging you can get all the components that you need.
Ok cool thanks for confirmation.
Yes i know qcomponents.
I just found this one too : https://solen.ca/fr/produits/condensate ... 5a100k126/
Electric Wisdom
#32 Post by Electric Wisdom »
I will probably paint them black and use this as protection, with black metal corners and simple black handles.
http://www.canadiantire.ca/en/pdp/minwa ... p.html#srp
#33 Post by Bruce Weldy »
Electric Wisdom wrote: Mon Mar 05, 2018 12:13 am I will probably paint them black and use this as protection, with black metal corners and simple black handles.
You can do that, but they will most likely end up looking like homemade cabinets. Duratex is a much better finish. Looks professional and is very durable.
Electric Wisdom
#34 Post by Electric Wisdom »
Bruce Weldy wrote: Mon Mar 05, 2018 9:37 am
Yeah, i have hard time finding duratex in Montreal, i'll search again this week.
Also they suggest me not to use elect caps in pa cross overs... so i read a few online and see because they fail after years and maybe less precise as other caps... But then why bipolar elect caps are used in the design of the 212 simplexx? I would follow very carefully the plans but.. just checking if that might make sense or not? They sent me a list of other caps for example the 22uf :
https://solen.ca/products/capacitors/fa ... ne/pb1200/
Electric Wisdom
#35 Post by Electric Wisdom »
I like the fact that this finish i posted will make it look diy and cheap haha so it might be less chances for it to be stealed, also it looks like it will fill anything and make it very air thight on top of the PL glue that also expands.
I just found this thread, apparently i'm not the only one who can't find duratex here lol
viewtopic.php?t=4882
T_Gowan
#36 Post by T_Gowan »
Duratex available in Ontario Canada, pint, quart, US gallon .Has been for years. https://qcomponents.ca/Acry-Tech-DURATE ... BLACK.html
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Electric Wisdom
#37 Post by Electric Wisdom »
T_Gowan wrote: Mon Mar 05, 2018 4:05 pm Duratex available in Ontario Canada, pint, quart, US gallon .Has been for years. https://qcomponents.ca/Acry-Tech-DURATE ... BLACK.html
HA! thanks, a bit too expensive i think... also the shipping... i'm not orderign anything on their site at the moment... yes im a cheap dude haha
#38 Post by Bill Fitzmaurice »
You only get one chance to do it right the first time.
Electric Wisdom
#39 Post by Electric Wisdom »
Bill Fitzmaurice wrote: Mon Mar 05, 2018 4:54 pm You only get one chance to do it right the first time.
haha totaly, i will ask them to explain more and explain my goals.
I seem to not receive any email notifications even if i "subscribe" to my own thread.
#40 Post by Bruce Weldy »
Electric Wisdom wrote: Mon Mar 05, 2018 6:01 pm
I could be wrong but I think you only get email notifications on PMs.
Electric Wisdom
#41 Post by Electric Wisdom »
Using other than elect bipolar caps will change the sound, cross over point, etc? Or it's more about the durability or other factors? I trust your design, that's just good sense to use as close as possible as the intended design.
Electric Wisdom
#42 Post by Electric Wisdom »
Bruce Weldy wrote: Mon Mar 05, 2018 6:20 pm
I checked, nothing in my pm
Electric Wisdom
#43 Post by Electric Wisdom »
Hm.. they replied telling me about getting higher voltage caps is better when i ask about why they dont suggest the elect caps type... it's weird answer.. anyway, 100v caps is what the document says, he says i must use more than 112v caps because 800w amp will give 112v...
Why the 2 woofers 3012lf at 450w each would be ok with caps rated at 100v?
Last edited by Electric Wisdom on Mon Mar 05, 2018 10:06 pm, edited 1 time in total.
#44 Post by Bill Fitzmaurice »
Electric Wisdom wrote: Mon Mar 05, 2018 9:53 pm Hm.. they replied telling me about getting higher voltage caps is better when i ask about why they dont suggest the elect caps type... it's weird answer.. anyway, 100v caps is what the document says, he says i must use more than 112v caps because 800w amp will give 112v...
Rule #1: Follow the plans. Rule #2: Never break rule #1. Where they say use electrolytic use electrolytic, where they say use polys or mylars use polys or mylars. Where voltage is concerned look up the definition of 'at least'.
Electric Wisdom
#45 Post by Electric Wisdom »
Bill Fitzmaurice wrote: Mon Mar 05, 2018 10:02 pm
Yeah i will of course
Ah ok so if i have 2 of theses 3012lf 450w i add 450+450= 900w minimum?
I mean how i know how much voltage for caps i need? I will use 100v min but is it overkill to go higher than like 600v ?
