Re: 8 x DR250 build
Posted: Wed Nov 25, 2015 12:48 am
I finally got all the PVC reflectors mounted
. They took awhile as I had to custom mold all 32 of them to the right diameter as I couldn't find any PVC schedule 40 pipe in stock so I had to use PVC sewer pipe. I hope that doesn't make my DR's sound like sh@t. There was a sign for the schedule 40 next to an empty shelf. I asked about it and the guy said they weren't getting anymore in stock. It is either a seasonal thing here (winter time here now) or they are phasing out PVC as I couldn't find any PVC couplers for the vents as well although they did have the 2" pipe. So, for the vents I went with ABS as they did have that in stock. The hot melt doesn't stick as well to the ABS as the PVC but I think I'll be OK.
The flex in the horn sheaths was bothering me so I added some 5/8" x 1/8" strips again leaving plenty of room for the vent and I left out the middle section as the middle brace will support that:
Even though the strips are only 1/8" wide x 5/8" tall, the difference is substantial when you push on them or knock on them. It sounds and feels solid now. I was originally going to put another strip on top of them to make an "I beam" but it wasn't necessary. I didn't cut out the radius or fit them precisely, just lots of PL to fill the gaps. I let that set up overnight and then the next day went in with a syringe filled with PL to fill any missed spots.
I then did some bodywork to everything but the outside of the cab. I filled all the staple holes, sanded and filled any joint lines and pretty much got everything ready for paint as I will be painting everything without a grill. I know there are panels yet to add but the random orbital won't be able to get everywhere once those panels are attached:
Not that great of a picture but that joint is smooth now!
I guess that's the end of that phase. Next up will be the compression horns and modules. I might need some luck to figure those out
Well that quote didn't make me feel any better, lol. Trying to sand hotmelt in that spot wasn't working and it was bothering me so I got a little carried away with the bondo:LelandCrooks wrote: Scrape the excess glue, sand it a bit, and you're good to go. I make them pretty just because I'm doing for somebody else who's paying me.
