Wedgehorn 10's W/ Urethane horns
heavybdrums
Re: Wedgehorn 10's W/ Urethane horns
#31 Post by heavybdrums »
Wh 10 all assembled, except for grille and corners, waiting for first coat Duratex to dry:
4x WH8 delta pro
2x WH10 Deltalite 2510
4x Dr250 Deltalite II 2510
8X Titan 39 3012lf, 28"
4X Tuba 60 W/ lab 15
heavybdrums
#32 Post by heavybdrums »
First of 2 Wedgehorn 10's finished:
4x WH8 delta pro
#33 Post by Tom Smit »
You have done some fine work, Bill.
#34 Post by Grant Bunter »
Very nice indeed Bill!
You might want to buy some 1/4" plug plastic blanks to fill those 1/4" jack holes when they aren't in use, if they leak...
heavybdrums
#35 Post by heavybdrums »
Tom Smit wrote:You have done some fine work, Bill.
Thanks Tom, I got much better at rolling the Duratex finish. I found that going back over each of 3 coats with a dry roller when it starts to dry removes some of the glossiness and the roller marks and creates a finish I like better. So much better that I went ahead and refinished the w8 I had previously finished.
4x WH8 delta pro
heavybdrums
#36 Post by heavybdrums »
Grant Bunter wrote:Very nice indeed Bill!
Thanks Grant ! Once the cable switch over from 1/4" to speakon is completed I will plug the 1/4" jacks, and already have the plugs. For these wh monitors, since they are vented (ports on the sides) it's probably not too important, but once i'm not using them I might as well plug them. In addition once I'm not using 1/4" jacks I will probably unwire them as well as plugging them. For now my main focus is getting the last monitor built, then will come the cabling switch over (already have the 12 ga wire and will continue getting the speakon ends as $$ allows). Then on to the 4X dr 250's which won't have 1/4" jacks. Hopefully the dr 250's will be completed before the new year, and then on to making the public aware of my availability for sound services (incl. gear sheets/bio, web site and business cards) to be ready for the next festival season. I believe I may call myself "Sun Sound Services". Then comes the subs, which for pack space will probably be the widest version of the Titan 39 with premium driver 3012lf that can fit through my 29&1/2" basement door.
4x WH8 delta pro
#37 Post by Grant Bunter »
heavybdrums wrote: I believe I may call myself "Sun Sound Services". Then comes the subs, which for pack space will probably be the widest version of the Titan 39 with premium driver 3012lf that can fit through my 29&1/2" basement door.
Good luck with your venture!
Just remember with the T39's, when it comes to doors it doesn't matter how wide they are, as you can turn them side on to get them through the door. Side on, maximum width is only 19 1/2".
So it goes back to pack space only...
heavybdrums
#38 Post by heavybdrums »
heck then, since I will be carting them around in a hand truck, loading them in sideways through my door is no problem, so the widest (28") would totally work. My personal vehicle is a ford e 350 (which has a 1 ton capacity), full sized passenger van(not extended like church vans), with removable seats, so far 4 monitors 4 tops and 4 subs with amp racks and mics, cables etc, etc, etc looks like it will all fit..tightly but fit. One day there may be a trailer involved....
4x WH8 delta pro
heavybdrums
#39 Post by heavybdrums »
the second of 2 w 10's coming together...same as the other one, and the last of the monitors to build at this point, though I can see building one more each w 8 & w 10 or some combination after tops (4X dr 250's)and subs (4X titan 39 or 48) are done.
4x WH8 delta pro
heavybdrums
#40 Post by heavybdrums »
Rain day from work, so I'm finishing off the last monitor with duratex today:
4x WH8 delta pro
heavybdrums
#41 Post by heavybdrums »
heavybdrums wrote:the second of 2 w 10's coming together...same as the other one, and the last of the monitors to build at this point, though I can see building one more each w 8 & w 10 or some combination after tops (4X dr 250's)and subs (4X titan 39 or 48) are done.
It's been decided, once 2X Tian 48's and 2X DR250's are completed I will return to building 2 more W8. Then 2 more each of titans and dr's
4x WH8 delta pro
#42 Post by Bruce Weldy »
heavybdrums wrote:Rain day from work, so I'm finishing off the last monitor with duratex today:
First time I used duratex, I poured it in a pan too......
Now, I just dip right out of the can. It's thick enough that it doesn't drip and I don't have any waste or additional cleanup.
heavybdrums
#43 Post by heavybdrums »
Woofer breakin, thanks for the tip Tom,
Tom Smit wrote:I've broken-in drivers by hanging them on a tarp strap.
https://www.google.ca/search?q=tarp+str ... d=0CBwQsAQ
Tweeter array wired:
Tweeter array front:
Cab top and back:
all done cept grille:
All finished and grille:
And that's all for the monitor builds for the time being, now on to Titan 48's
4x WH8 delta pro
#44 Post by Tom Smit »
YW.
