DR250 Build, Perth Australia
kekani
Re: DR250 Build, Perth Australia
#31 Post by kekani »
Wait, just realized, doesn't this mean the end angles are the wrong way as well?
Wedgehorn 6 (x2)
Jack 110 Lites (x2)
XF212 (Egnater style)
DR200 ASD (Yes! Finally!)
SimonD
#32 Post by SimonD »
kekani wrote:Wait, just realized, doesn't this mean the end angles are the wrong way as well?
I'ts only the angle that is the wrong way, but as I said, I can slice off about half an inch of the angled edge at 90deg, turn it over , and glue it back on the right way round.
2 x DR250 (Kappalite 3010MB, ASD1001S)
2 X T39 24" (Kappalite 3012LF)
#33 Post by Grant Bunter »
Enjoying your build and your honesty!
Keep up the good work...
SimonD
#34 Post by SimonD »
Not a lot of progress this week as I have been getting my rehearsal space sorted out.
I managed to get the sheaths on and sealed.
SimonD
#35 Post by SimonD »
Got the first of the side braces on
Trimmed and cleaned up the overhang on the sheaths.
I also got a coat of primer undercoat on the inside surfaces that are about to be hidden forever :-)
SimonD
#36 Post by SimonD »
Hi Folks, Good progress this weekend :-)
I'll start with fixing the little mistake on the HF module where I glued the flange faces on upside down so that the angle was the wrong way round. I simply cut the edges off with a circular saw.
And glued them back on the right way round
I fabricated the compression module horn assemblies
And fitted them to the flanges
Notice that I left a ¼’ gap at the ends where I will put a little cover plate to seal the module as per an earlier discussion.
SimonD
#37 Post by SimonD »
After another little error where I aligned the centre brace with the middle of the front of the cab instead of maintaining the offset, I removed the brace and (with minimal damage to the surrounding timber) and glued it back in the right position.
I then trimmed and fitted the remaining side braces
And after masking the edges got a couple of coats of undercoat sprayed on.
I am pretty happy with the finish that I'm getting with the spray gun and I find it much more satisfying than painting with a brush, which I absolutely hate :-)
SimonD
#38 Post by SimonD »
HF modules are looking good with a test fit showing no issues.
I picked up some decent speaker wire today so I now have all the components other than the Duratex.
I am still not 100% on the colour scheme but I think I might go for red horn faces with black bracing.
#39 Post by AntonZ »
SimonD wrote:I was able to fit the T-nuts. I recessed the woofer spacer with a 7/8 flat blade boring bit.
Fitted the T-Nuts
And mounted the spacers (after confirming that I could actually get the drivers in when the side covers will be fitted :-))
It took me a while to see, but I would think there is not that much "meat" left between your T-nuts and the driver, once installed. Tighten them real fast, and you risk pulling the T-nuts through the spacer. I would rather have had the T-nut on the other side, yet another 1/2" further away from the driver, if you know what I mean. I'm not a native english speaker, so searching a bit for understandable wording here. Not sure about wording, and about my point. Others may chime in.
Other than that, great build thread, lots of pictures, always good.
SimonD
#40 Post by SimonD »
Hi Anton, the T-nuts are only recessed 1mm into the back of the spacer. That leaves 11.7 mm of "meat". That is plenty! I don't intend to over-tighten them and I will put a lock washer on the cap-head screws. It would take an enormous amount of force to pull a 20mm T-nut through the timber and I hope I'm not that "ham-fisted" :fingers:
I take your point of going through both pieces of timber though. I could still do that if I run a drill and tap through the centre of the T-nut and put a lock nut on the back.
Cheers S
SimonD
#41 Post by SimonD »
Somewhere under all those clamps is a HF module with the first sheath being glued on to it. I think I'll make a jig to glue the others :-)
SimonD
#42 Post by SimonD »
Happy to report lots of progress this weekend :-)
I fitted the custom cover plates on the end of the HF modules. A fairly simple task of tracing the outline directly from the module and cutting it our with the band saw.
and glueing them in.
Next came the driver mounts that I cut out with a couple of hole saws. First the centre hole
Then the outside
And stuck them on
Also got the flange brackets and dowel installed (I left the dowels un-glued untill I have painted the modules)
SimonD
#43 Post by SimonD »
After two coats of undercoat/primer, the cabs got their first coat of black.
and the first of the back halves went on. I have had them pre-bent for a few weeks so didn't have any dramas with cracking or splitting. I didn't bother with nails or anything as I was able to get them fitted nicely with the tie-downs and clamps.
SimonD
#44 Post by SimonD »
With regards the dreaded nacelles, I have started making a template to drill the mounting holes. The plan at this stage is to make some timber tubes by drilling out the centre of pieces 5/8 (16mm) dowel. I will drill a hole in the module sheaths and mount the timber tubes through the sheaths down to the flanges but not through the cleats. I will use 8 x ¼ Cap head screws and T-nuts for each module.
It's pretty scary doing anything to the modules at this point as they take sooooo much work to get to this stage and I don't know if I could deal with a disaster. Drilling the holes in the sheaths is the really scary part as it can all go very wrong in a very short time.
The plan is to first drill the 1/4 holes in the flanges with the template. Then make a simple jig by attaching a piece of board to the drill press, big enough for the module to be moved around under the chuck. I will drill a 1/4 hole in the centre of the board and put a little 1/4 dowel in the hole. Then, without moving the drill press base, the module can then be perfectly aligned for each hole under the chuck using the 1/4 dowel stuck into the pre-drilled holes in the flanges. That's the plan anyway, any other suggestions would be gladly accepted! :-)
kekani
#45 Post by kekani »
SimonD wrote:With regards the dreaded nacelles, I have started making a template to drill the mounting holes. The plan at this stage is to make some timber tubes by drilling out the centre of pieces 5/8 (16mm) dowel. I will drill a hole in the module sheaths and mount the timber tubes through the sheaths down to the flanges but not through the cleats. I will use 8 x ¼ Cap head screws and T-nuts for each module.
You know, I saw Grant do something similar with the "tubes". I didn't get it, until I needed to. My laziness got the better of me and that's why I made the cleats out of 3/4" ply. Forstner bit through them and you have just drilled your "tube".
In your situation, I wouldn't even make full size cleats - just enough for the drill to make a "tube". Cut 16 pieces, glue, drill, done.
Although, Grant's PVC came out clean.
Of course, look who's talking - the guy that did the thread on how "not" to do it. . .
Wedgehorn 6 (x2)
Jack 110 Lites (x2)
