Re: "Hard limiter" that lowers output as input rises?
Posted: Wed Oct 08, 2014 6:01 pm
Thanks for the other possible uses CoronaOperator
Loudspeaker Design
https://billfitzmaurice.info/forum/
Sorry I missed this part earlier!escapemcp wrote:Quick related question:
I have been testing my mixer to see the point at which it clips. I have used sine waves (as you can easily hear clipping with these) at various frequencies. If I can get my mixer to, say, +8dB when it clips (happens at the same point with all sine wave freqs), can I safely assume that I can take a broadband signal to +8dB without any clipping?
I currently HAVE made that assumption, and have soldered in some resistors into the XLR chain in order to reduce the levels going into the DEQ, so that clipping on the mixer happens at the same time as clipping on the rest of my kit. This keeps SNR ratio high and avoids any nasties from dropped mics, needle thumps etc.
I started with the side chain compression.Grant Bunter wrote:I did suggest this on page one. But I wasn't sure if the OP has a DCX.
Then explain how this "hard knee" limiter works :bjm362 wrote: A position of a slider isn't a guarantee,it still depends on content of signal!
I really like that one !!!! OLD SCHOOL TO THE MAX!!!!!CoronaOperator wrote:Then explain how this "hard knee" limiter works :bjm362 wrote: A position of a slider isn't a guarantee,it still depends on content of signal!
Your speaker management should be set and left alone during the gig. Once you have your crossover and limiter set (which should be before you ever reach a gig) - all that's left its to get the EQ right.....bjm362 wrote: I comfortable with using my active crossover, but not so much with my limiter/ loudspeaker management system. In the old days I could handle it myself at DJ gigs. I could ride shotgun at festival gigs/raves etc. However that won't work if I am on stage singing and there really isn't a sound guy! I can't be in both places at the same time!
bjm362 wrote: I may be looking at it from the wrong perspective...but the next to the last pic looks like it depicts a lot of distortion where the limiter is really clamping down.
Hope I got this right.CoronaOperator wrote: ... and a pic of the low shelving EQ engaged to maximum (sorry, no smoothing on this one) :
bjm362 wrote: BTW, do you have a thread around here about your band? What area? Are you on facebook? Does your band have a Facebook page?
Yes.SoundInMotionDJ wrote:I get that a "hard limiter" can be setup to provide a maximum output for any input above a certain level. I have that now. But, it's not working. DJs who get on my system continue to push the DJ mixer into the red and produce an overcompressed mess...and I get the blame.
I am looking for an effect to help me keep overzealous DJs in check. I want a limiter that will allow the "maximum" volume to be passed when the mixer is at some 0dB level of output.
BUT...if the DJ mixer level is raised above the 0dB level, I want the final output to go down from that 0dB point. So, if the DJ mixer is at +6dB, I want the output of the limiter to be -6dB (or whatever ratio I set).
Is there such a device?
