SPL meter acting weird
Re: SPL meter acting weird
dont put the mic on such a pedastal
. It may be good quality, it might be pretty flat, but I doubt its razor flat. unless it had a price tag of over 500 it is certainly not flat abouve 5khz, and likely has some LF anomalies as well.
Here's an idea for you MC,
Play the same song/material, at the same volume/voltage, take your new meter out into the corridor with your room door open, and take a new measurement.
Since I've been here on the forum, plenty of people, running any sub at all, in a small room, have observed lack of the lowest of the lows they expect from their cab.
It's also often been said in response to these observations that these designs like a bit of space to perform to their best.
Door open, measuring in the corridor, will do exactly that, and may lead you to different results...
Main reason I say it's flat is because it is calibrated flat from Dayton (personal eq file) to within half a db. I will definitely try out what grant mentions. Also by design it doesn't roll off at 60 hz like c weighted spl meters do.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
2 x TLAH
SLA Center
1 x 212 TH (custom)
I walked around a bit with a 25 Hz sine wave going at 2.9 volts. Here is what I got, my computer area was around 83 dB (7 feet from subwoofer) 2 feet next to it was 82 dB. Now I know it's not the subwoofers fault because...
The opposite side of the room next to my mirror (~10-12 feet) was 93 dB. Thus "1 w/1m" for the sub should be around 93+10+5 - 12 = 96 dB at 2.9 V accounting for corner loading, c-weighting, distance, while assuming spl meter accuracy. In other words, yes, it takes most of the room to even get to an area where the 25 Hz doesn't undergo massive room cancellation. the ~3 dB difference with the chart comes from cabin gain as explained by Bill somewhere. Once I take it outside I'll do proper 1w/1m measurements which will be this weekend assuming the paint dries quickly.
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
It's pretty hard to come up with a quality calibrated reference microphone for $100 or so. Here's a link to a company that's an authority in this field. I'm not suggesting anyone need go purchase one of these, but it will help anyone performing tests to be aware of the shortcomings of a bargain basement mic.
http://www.bksv.com/Products/transducer ... idges.aspx
http://www.bksv.com/doc/be1447.pdf
T48s
WH8s
SX212
T48s
WH8s
SX212
For my purposes, the +- 1 dB accuracy of the dayton xlr calibrated mic is more than sufficient. I'm not trying to publish my results, I just want to room correct and compare my (relative) spl curve to that of the official SPL forum page. Both of which it has handily done. I got it flat to 35 in one listening position and well it's a bad room so the low bass requires a different sitting position.byacey wrote:It's pretty hard to come up with a quality calibrated reference microphone for $100 or so. Here's a link to a company that's an authority in this field. I'm not suggesting anyone need go purchase one of these, but it will help anyone performing tests to be aware of the shortcomings of a bargain basement mic.
Thanks again all for enlightening me with all these other choices I didn't know I had.
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
