First Omni 15 Full Range build...
Re: First Omni 15 Full Range build...
So long as you finish with all your thumbs...
On that theme you want to build a panel cutting jig as well, much safer. There is some stuff to know about how to not get in the firing line of a kickback and keeping thumbs intact.
It would be a good job for Harley to write up a guide, he had a close call last year, impaled the back wall. Too scary for me, I don't own one.
- All Thumbs
ThanksAntonZ wrote:They do indeed look quite a bit better than the first pair. Well done
First time builder of 2 x Omni 15 Full Range - wish me luck
Scott Whitley Bass Guitar Services
Web: http://www.scott-whitley.com
Facebook: http://www.facebook.com/scott.whitley.bass.services
- All Thumbs
Indeed!!!!Gregory East wrote:So long as you finish with all your thumbs...
- Chris_Allen
Or give up slap.All Thumbs wrote:Indeed!!!!Gregory East wrote:So long as you finish with all your thumbs...
- All Thumbs
BLASPHEMY!!!!Chris_Allen wrote: Or give up slap.
Common sense
- All Thumbs
AntonZ wrote:Common sense
- All Thumbs
Enough horsing around...
- All Thumbs
So I got the filters built
- All Thumbs
....and the horn glued into cab one...
- All Thumbs
Horn now sanded
That is looking mighty spiffy indeed! Keep it up!All Thumbs wrote:Horn now sanded
- Bas Gooiker
Wow, is that even the same cab?
- All Thumbs
I know - amazing the difference when all that glue and filler's sanded downBas Gooiker wrote:Wow, is that even the same cab?
- All Thumbs
Thanks - determined to get cab 1 finished within the next week although I'm not going to rush anything....miked wrote:
