Re: SLA ht build
Posted: Tue Mar 26, 2013 7:38 pm
LOLBill Fitzmaurice wrote:Old? I've got hemorrhoids that are older than you are!lancemhorsley wrote: I am 25 and am starting to hate getting old.
I think I just peed a little bit...Bas Gooiker wrote:But seeing them in your piece of beauty made me cry a little.
Are you screwing with me Ian? Just because i feel those screws screw up the baffle?Ian Westwood wrote:I think I just peed a little bit...Bas Gooiker wrote:But seeing them in your piece of beauty made me cry a little.
Personally I hate seeing screws... and I'm sure he's not done yet... and this is a fantastic build. Kudos to the OP.Bas Gooiker wrote:Screw it...
Well I thought I was one of those freaks that preferred the screws in the front, But turns out I don't like them either. I am going to look for smaller screw heads so they are not as noticeable.Bas Gooiker wrote:Your cabs look nearly pornographic!![]()
I never understood why people put screws in the front baffle anyways. But seeing them in your piece of beauty made me cry a little.
Sure, you can easily pop them back out if you use a piece of cardboard roll and your vacuum cleaner and gently suck them back into shapelancemhorsley wrote:So after waiting patiently for the speakers to arrive they do and I am stoked to get one put together. So I set them in place to make sure they fit nice, and then i leave the room for a short second. When I return I see my son pushing and making dents in each. He ended up doing this to 3 speakers is there a simple way to pop the dent back out? I sure hope so.
I had that happen and I just used my mouth to pop them back out.Michael Ewald Hansen wrote:Sure, you can easily pop them back out if you use a piece of cardboard roll and your vacuum cleaner and gently suck them back into shapelancemhorsley wrote:So after waiting patiently for the speakers to arrive they do and I am stoked to get one put together. So I set them in place to make sure they fit nice, and then i leave the room for a short second. When I return I see my son pushing and making dents in each. He ended up doing this to 3 speakers is there a simple way to pop the dent back out? I sure hope so.
LelandCrooks wrote:Those are spectacular. Utterly.
