I just glued in the last set of braces on the 1st of 4 T39s.
Re: I just glued in the last set of braces on the 1st of 4 T
#31 Post by Bill Fitzmaurice »
el_ingeniero wrote:There are for equidistant leaks each centered between a pair of screws. It's the gap between the gaskets. I have the screws cranked down hard to where they won't go any further, and I still hear the leakage.
It looks like I'll need to pull the driver and stick a dab of silicone in the space twixt the gaskets?
Seal it externally with a dab of hot melt glue.
el_ingeniero
#32 Post by el_ingeniero »
Sweet! I got one of those! Thanks, Bill!
el_ingeniero
#33 Post by el_ingeniero »
Ended up being a bit more than a dab, but I did get it sealed up. Ran some 60Hz at 13V through it, and yeah stuff was shaking. Time to finish up the other one, and work on DRs.
