Behringer EP vs iNuke vs Peavey IPR
Re: Behringer EP vs iNuke vs Peavey IPR
#31 Post by Grant Bunter »
Fourthlaw wrote:
Grant Bunter wrote:Pick a frequency, say 60 Hz sine wave. ... If you don't think this is going to max out amp voltage, select different frequencies.
Would it make sense to pick 3 (or 5) "forum standard" frequencies, say: 40, 60, 80, 100, and 125 or whatever? I guess then take an average or the highest, maybe?
Would that provide more consistent results or just be more work than it is worth?
Good point!
Since maximum excursion is often at the lowest frequency of the cab you need to make sure that your voltage isn't exceeded there...
SirNickity
#32 Post by SirNickity »
That depends on the frequency response of the amp. Ideally, it should be +/- very little throughout the entire range. Crossover filters will affect this, since the "filter frequency" is a corner, and not an absolute. Picking a value dead-center between the HP and LP points will minimize that.
Unfiltered, the only change (again, ideally...) should be due to the AC coupling characteristics of the output stage, or the bandwidth limitations of the extreme HF.
If anyone finds differently I'd be interested to know, because the specs are published such that it should be a non-issue.
Chris Betancourt
#33 Post by Chris Betancourt »
anyone has tested the output voltage on the iNuke 3000 and 6000??
Christopher Betancourt
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
