If I am spraying something that will have rubber feet, I put some long screws just barely into the screw holes to use as "legs". I spray that side first, then flip the cab over so it sits on those screw legs. Then I spray the rest of the cab.DaveK wrote:Another thing to watch out for is consistency between coats. If you stand a cab on something to spray 5 sides, wait for them to try, then spray the last side, the odd side never looks exatcly the same.
If you were spraying a cab without feet but with corner protectors, you could probably make small holes that would be hidden by the corners, and don't go all the way thru the panel, and do something similar.
