Page 3 of 4
				Re: Titan 39 Down Under
				Posted: Sat Oct 22, 2011 10:50 pm
				To remove a panel, one could use a tool such as
http://ebictools.en.made-in-china.com/p ... 00JD-.html.
That was
all you got done?
  It doesn't sound like your taking your time.
				Posted: Sun Oct 23, 2011 4:57 am
				by Titanium Hand
				Bizarre, got the crown xti 2000 hooked up to the laptop. 3.5mm mini jack to neutrik xlr for the signal input. Running sinewave generator almost on full steam @30Hz only 12.5 volts AC into 8 ohms? I was expecting a whole lot more. On the second last notch on the dial the display lights are only on -20dB. Is it possible that a lack of input voltage from the laptop is causing this piss weak output? Help please
				Posted: Sun Oct 23, 2011 5:39 am
				by Gregory East
				I can get 1.4V in stereo out of my laptop, running audacity. It has to be turned right up on both the computer and the audacity output.
I'm not sure how that translates when you take an XLR off an unbalanced half of a stereo unbalanced conection. My guess is you would get 0.7V, ie enough. But easy to check.
I'd have to go googling to find input sensitivity for the amp, over to you at this hour of night, we just won the rugby!
				Posted: Sun Oct 23, 2011 6:41 am
				by Titanium Hand
				Thanks Gregory, Come on the New Zealand aye!
				Posted: Sun Oct 23, 2011 9:41 pm
				by Titanium Hand
				well I'm finally almost finished. got the rest of the construction completed last night. drivers burnt in at 30hz for 12 hours between 9.8 & 10 volts. Still incredibly concerned at the lack of output from the crown xti 2000.
  "hopefully" between 100 & 45Hz the amp will be able to muster a little closer to the cab limit of 50volts. Is there anything else I can do to help it along? signal pre-amplifier or something?
My afternoon is to be spent wiring the speakons & drivers into the cab's and loading them up with weather stripping.
my first observations of the cabs, sans drivers is; they really aren't that big, weigh nothing and look fierce as hell
looking back...I'm buggered... and really about enjoy my beer in front of my new titans on this glorious 30 degree + celsius day
				Posted: Sun Oct 23, 2011 9:45 pm
				by Jon Barnhardt
				Just wired my second one up today after curing for almost 36 hours and they are glorious indeed. (at even only 30 volts)
				Posted: Sun Oct 23, 2011 10:26 pm
				by Gregory East
				Titanium Hand wrote:well I'm finally almost finished. got the rest of the construction completed last night. drivers burnt in at 30hz for 12 hours between 9.8 & 10 volts. Still incredibly concerned at the lack of output from the crown xti 2000.
Amp shouldn't have any problem producing 30Hz.
You said the input meter on amp was down. Some amps need .7V and others 1.4V to drive them up to maximum. I believe the ones needing 0.7V are getting a balanced signal so it's actually 1.4V in total.
Look to your wiring if the output of the laptop isn't down. Your best bet is wiring one channel in an unbalanced XLR. Off top of my head I can't remember how that's meant to go but the Rane note that Bill posts from time to time will tell you. Number 110 iirc.
				Posted: Sun Oct 23, 2011 11:26 pm
				by UROK
				Titanium Hand wrote:well I'm finally almost finished...
Spoken like a true addict!
You're bu**ered, mate!
				Posted: Mon Oct 24, 2011 12:46 am
				by Titanium Hand
				Posted: Mon Oct 24, 2011 1:35 am
				by UROK
				Oh dear. You're BFD addiction is more serious than I thought!
You really are bu**ered, TH mate!!
				Posted: Mon Oct 24, 2011 2:25 am
				by Gregory East
				Slow down there dude. Others have put cart before horse in their enthusiasm and come unstuck.You sealed the driver by sitting on the access panel? Try following the instructions before you blow a driver.
				Posted: Mon Oct 24, 2011 3:51 am
				by Titanium Hand
				Thanks guys.
Instructions followed. I turned it off. And re-assessed the situation with a level head albeit a smiling one.
I have to get a tap for one of the driver hurricanes, epoxy in it causing me grief. No matter how careful one is you can never underestimate the will of epoxy, it behaved like friggin mercury.
A second M6 tap required for three of the ten tee-nuts in the front door 5A.
I've had the Multimeter on the back of the speakon going into the cab, it was bloody pumping and only reading like 13.2 volts! These are INSANE System architect a breeze for crossover settings as per plans. Researching the limiter this evening.
Any advice in using a tap? (not a faucet) Is it something like a quarter turn forward, eighth of a turn back proceeding all the way through. Thanks guys.
				Posted: Mon Oct 24, 2011 4:15 am
				by Harley
				Titanium Hand wrote:Any advice in using a tap? (not a faucet) Is it something like a quarter turn forward, eighth of a turn back proceeding all the way through. Thanks guys.
Yes.  But sometimes even 1/4 turn can be too much.  Turn until you get some concerning resistance, then back off 1/2 of what you have turned.
Use a cutting fluid or something like INOX which is available in OZ on your tap.
				Posted: Mon Oct 24, 2011 8:02 pm
				by Titanium Hand
				Thanks Harley, I bet your most pleased with the world cup result? I've never seen soo many 'Silver Fern' flags around
So I got the taps this morning. The old mate in the engineering supplies pretty much said word for word what you said! I've got the INOX too.
With my second cab, I trial fitted all of the bolts, again, just to save headache. Not one of them offered any resistance. Although I have a bloody leak, so very slight where the driver mounts to the baffle backer. I understand that Silicone based sealers are off limits.
 Any idea of a suitable caulking compound or similar that is readily available for me to fix up the leak?
I was considering getting an acrylic based sealer from Fullers? Bunnings (big box hardware) have a monolithic range of Fullers gear. Thanks in advance. I'll be tapping the epoxy out of the threads this evening.
				Posted: Tue Oct 25, 2011 12:42 am
				by Harley
				Titanium Hand wrote:I was considering getting an acrylic based sealer from Fullers? Bunnings (big box hardware) have a monolithic range of Fullers gear. Thanks in advance. I'll be tapping the epoxy out of the threads this evening.
If you can get hold of it Holdfast MSS 220.  If not any Fullers MSS ( Modified silicon ) but leave it 48 hours to set.  I will go like rubber.
