+1Bruce Weldy wrote:Better yet, just use this...Jon Barnhardt wrote:See this thread for some voltage indexes: http://billfitzmaurice.info/forum/viewt ... =7&t=16062Dan30 wrote:
I need to do some more reading but i'm on the right track now.
http://www.sengpielaudio.com/calculator-ohm.htm
so I got my first t30 running..
- Jon Barnhardt
Re: so I got my first t30 running..
Could not find too much valuable info about the questions I'm asking.. It's much more build orientated topics there. What I need to know is: should I measure voltage at the lowest frequency set by the hpf for setting limiters? This is where I get highets voltage swing, but people seem to use higher frequencys so I'm a bit confused..Bill Fitzmaurice wrote:Only so much can be put into the plans. OTOH there's this:osse wrote:How come no info is included in the plans on how to set the limiter correctly? Or am I missing the point somewhere? I'm sorry for being noob if that's the case..
http://billfitzmaurice.info/forum/viewforum.php?f=14
Also:
As you recommend the dbx Driverack series in the plan, I guess it's green light, would you care to comment?Dave Non-Zero wrote:the driverack PA doesnt have brickwall limiters!
they have a minimum attack time that will allow high transients through.
what does this mean? -
using pink noise and setting the output voltage of the amp to just below clip light comes on, you can turn the pink noise up as far as you want and the limiter will keep it from clipping. BUT. run some music with a beat thru, and turn it up and the limiters will be on, but the beat will still clip your amp.
the limiter takes a small amount of time to clamp down on the signal, allowing transients thru for a short while.
so you cannot rely on the driverack to completely save your drivers if you use a large amp and run it hard into the limiters.
Thanks guys for the help!
already answered, read againosse wrote:. What I need to know is: should I measure voltage at the lowest frequency set by the hpf for setting limiters? This is where I get highets voltage swing, but people seem to use higher frequencys so I'm a bit confused..![]()
If your tunes only tickle the limiter infreqently your largest peaks will not be so much in excess of the limit. If you are in the habit of ignoring advice ( seems likely ) you will be pushing lots of larger musical peaks through the limiter.osse wrote:Also:
There must a be some element of conservatism in the plans voltage limit as there is no history of BFM drivers blowing up on those following the rules with the driverack.
Gregory I'm sorry if that seem like case, but it really isn't... I'm very greatful for all you guys helping me out and I'm just trying to get the whole picture, but I guess I'm a bit bold.Gregory East wrote:already answered, read againosse wrote:. What I need to know is: should I measure voltage at the lowest frequency set by the hpf for setting limiters? This is where I get highets voltage swing, but people seem to use higher frequencys so I'm a bit confused..
Sorry guys
Anyway, I noticed some airleaks, and I'm gonna experiment more with the amp at lower gain settings and get a lower power amp soon!
Thanks!
I just got this...thing leak free and running in the corner...
What the fuck is this monster I've built?
One is... extreme, and she will get 3 sisters..
Guess it will come handy outdoors..
I don't think you looked very hard. I mean really, it's on the first page: http://billfitzmaurice.info/forum/viewt ... =14&t=8755osse wrote:Could not find too much valuable info about the questions I'm asking..Bill Fitzmaurice wrote: Only so much can be put into the plans. OTOH there's this:
Great threadBill Fitzmaurice wrote:I don't think you looked very hard. I mean really, it's on the first page: http://billfitzmaurice.info/forum/viewt ... =14&t=8755osse wrote:Could not find too much valuable info about the questions I'm asking..Bill Fitzmaurice wrote: Only so much can be put into the plans. OTOH there's this:
when I'm on 47,4 vRMS at 60 hz, at the same settings it's showing 57-58 vRMS over 41-49 hz. Is this no problem? Or should I limit from the sine wave that yields the highest vRMS output? This might be logical to some... but I don't wanna blow my driver but I at the same time don't want the cab to perform at a lesser level than it could...
That is a mystery to me. The only way I can see that happening is if you set the lowpass on the subs too low.
35.5 Hz. Might be the amp emphasizing?Gregory East wrote:That is a mystery to me. The only way I can see that happening is if you set the lowpass on the subs too low.
35.5 Hz will be your high pass not your low pass, or else you have royally screwed up setting your crossovers.
Right ya are, read it wrong.. would be cool with 0.5 hz bandwith before filters kicking in tho..Gregory East wrote:35.5 Hz will be your high pass not your low pass, or else you have royally screwed up setting your crossovers.
Lp is set to 106 Hz 12dB BW filter right now, so it won't be the problem
Been building 10 hours straight.. second one is taking form! Much smoother this time, great learning curve and the plans are just awesome!!
Love building these badboys..
I guess they wont be very gentle if pushed
- Harley
Get a load of this statement you plonkers who do nothing but moan about the plans!osse wrote:... and the plans are just awesome!!...
- Scott Brochu
I had to google this one. Never heard it.Harley wrote:plonkers
sick.... but funny.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
- Harley
No. God gave me just one shot at this and so he made me a humble Bass PlayerScott Brochu wrote: You sure you never were a drummer in a past life?
But I live in a country that is always looking from the outside in, PLUS we have a lot of Poms and Aussies living here PLUS we have USA propoganda via Hollywood and so on and so on. That means we get a HUGE variety of funny things to pick from. Take the best and leave the rest...That's why Gregory and I are like we are
