My build of a Tuba HT sub
Drey Chennells
Re: My build of a Tuba HT sub
#31 Post by Drey Chennells »
wormraper wrote:
Harley wrote:There're three tricks to successful tee-nutting
1) Buy the more expensive but larger tee nuts with 4 claws,
2) Epoxy the back of them, and
3) Run a thread tap through them prior to trial fitting the driver and putting bolts in them.
1.... will do
2... plan on doing that
3.... ummmm. sorry to sound stupid what what does "run a thread tap through them" mean :oops:
running a thread tap..
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
wormraper
#32 Post by wormraper »
so from that picture I'm deducing that it's just running something through the drill hole to clean out debris???
#33 Post by Bill Fitzmaurice »
wormraper wrote:so from that picture I'm deducing that it's just running something through the drill hole to clean out debris???
Google 'tap and die'.
wormraper
#34 Post by wormraper »
ahhh, interesting... so you're creating threads for the T-nut... interesting... I'll see if HD has one when I go back this afternoon looking for weather stripping
#35 Post by Bill Fitzmaurice »
Not creating them, cleaning and restoring them. The die does the same with the bolt.
wormraper
#36 Post by wormraper »
ahhh, lol, sorry for the questions... I can be a bit noobish about tools... (it be why I'm taking this one slow)
wormraper
#37 Post by wormraper »
well, while I'm waiting for my wood building buddy to come back so we can work on panel 3...
my partner was thinking instead of using weather stripping or speaker gasket go get a rubber 1/16th inch gasket like at checker and seal that down to the wood instead.... the stuff like you would use for a car (for panel 3 and the access panel)
http://www.allstategasket.com/info_gask ... e-1187.asp
(that's his idea not mine).... I was wondering wouldn't 1/8 inch thick pvc foam weather stripping from home depot work the same as the speaker gasket tape from parts express????
and last but not least.... is this what I would need to run the thread tap???
http://www.homedepot.com/h_d1/N-5yc1v/R ... ogId=10053
Dave Non-Zero
#38 Post by Dave Non-Zero »
I've used the weather strip style stuff for access covers. The gasket tape is prob slightly better. As for the rubber stuff- Nah, don't think it would be as good at irregular gap filling as the foam tape.
The tap looks right, but you need the handle to go with it.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
wormraper
#39 Post by wormraper »
Dave Non-Zero wrote:I've used the weather strip style stuff for access covers. The gasket tape is prob slightly better. As for the rubber stuff- Nah, don't think it would be as good at irregular gap filling as the foam tape.
got it.... parts express gasket tape and speaker mounting kit it is then...
lol, yeah, I noticed that now that you think about it.... no handle that was just the bit basically... time to go to lowes to scout out the taps...
wormraper
#40 Post by wormraper »
ok, I just realized that the MFW-15 driver I have already has a gasket around the edge... is it still recommended to lay down gasket tape around the edge of the driver hole and seal the driver gasket to the gasket tape???
#41 Post by DJPhatman »
wormraper wrote:ok, I just realized that the MFW-15 driver I have already has a gasket around the edge... is it still recommended to lay down gasket tape around the edge of the driver hole and seal the driver gasket to the gasket tape???
Only if you get leaks around the gasket, when installed. I would say "install it now to be safe." If I have the gasket tapa available, I'll use it. I don't like having to take drivers out once they are mounted the 1st time.
wormraper
#42 Post by wormraper »
sweet... just wanted to make sure it wasn't detrimental to double up on the gasketing if not needed. but yeah, got 50 feet of gasket tape, might as well be safe than sorry
wormraper
#43 Post by wormraper »
haven't posted pics or updates for a few days so here goes
wormraper
#44 Post by wormraper »
I have one quick question... I'm literally on the last cuts and have like 1 piece of wood leftover for one of the final reflectors.... the 2 "3.5 inch" reflectors near the top (panels 1 and 2 and panels 1 and 8 reflectors) ... 1 cut one of them exact and the there is one scrap leftover that is 3 inches instead of 3.5 inches (otherwise I'll have to go buy a whole nother piece of baltic birch)... do they both have to be PERFECTLY identical or is one at 3.5 inches and one at 3.0 inches ok???
#45 Post by Bill Fitzmaurice »
wormraper wrote: is one at 3.5 inches and one at 3.0 inches ok???
That will be fine.
