SPL ?
Re: SPL ?
#31 Post by LelandCrooks »
leamy_f wrote: you would not wish tinnitus on your worst enemy.
No shit Sherlock. It just appeared in my left ear out of nowhere about a year ago. It's all in the upper range, 6k and above, but I'm up to 60db down 7k and up.
The right is as good as ever, hears up to 15k easily, which is damn good for being in my 50's and working around engines all my life.
Etymotics are worth every penny. I gave my opera singing daughter some. You would not believe the stage volume with an opera.
shane2943
Re: SPL ?
#32 Post by shane2943 »
Are these the Etymotics y'all are talking about?
http://www.etymotic.com/ephp/er20.html
Gauss
Re: SPL ?
#33 Post by Gauss »
I'm totally a tightwad when it comes to money, but I spent the $120 on molded musician's plugs from an audiologist. These have been invaluable. I even lost a pair (!!) and bought another. It's a good, comfortable fit, and best of all, I can hear clearly. At high volumes, I hear things others can't because their ears are being overwhelmed (like vents rattling.) Some of the best money I've spent as a musician - I can enjoy the music instead of being irritated by the volume.
BASS: Combo Amp & Titan39
Re: SPL ?
#34 Post by Chris_Allen »
Dave, is your meter calibrated properly?
UROK
Re: SPL ?
#35 Post by UROK »
Tinnitus is debilitating. The etiology is not fully elucidated at this time so treatments are palliative - there are some apps like Ringing Relief, for example. Chinese herbal medicine and acupuncture may also help in some cases.
Dave Non-Zero
Re: SPL ?
#36 Post by Dave Non-Zero »
Chris_Allen wrote:Dave, is your meter calibrated properly?
I just bought it off the shelf in Maplins. +/- 1.5 dB if I remember right. Do they not come calibrated?
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
SeisTres
Re: SPL ?
#37 Post by SeisTres »
Try this: put 2.83 volts into one of you speakers which has a chart for it, put the mic one meter away, and see what you get.
Re: SPL ?
#38 Post by Chris_Allen »
Dave Non-Zero wrote:I just bought it off the shelf in Maplins. +/- 1.5 dB if I remember right. Do they not come calibrated?
They should come calibrated, but the tolerance could be further out. A range of 3dB is pretty big but I supposed you aren't doing an exact measurement and need it more as a guide.
I like SeisTres's suggestion.
Dave Non-Zero
Re: SPL ?
#39 Post by Dave Non-Zero »
It was just a cheap one. I thought about getting the more expensive one but figured I would only need it if I was doing serious cab measuements.
Seems a bit circular to use a cab that may not be perfectly to spec to calibrate a meter that I'lll use to measure the cab. ;)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
SeisTres
Re: SPL ?
#40 Post by SeisTres »
Dave Non-Zero wrote:It was just a cheap one. I thought about getting the more expensive one but figured I would only need it if I was doing serious cab measuements.
Do you have anything commercial? It's pretty much along the same lines of having a commercial speaker at a shoot out as a control to see if there are any anomalies in the measuring procedure.
Dave Non-Zero
Re: SPL ?
#41 Post by Dave Non-Zero »
Oh so now I'm meant to believe commercial marketing bs specs? ;) hehe
I think I'd rather trust my SPL meter. :D
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
SeisTres
Re: SPL ?
#42 Post by SeisTres »
Dave Non-Zero wrote:Oh so now I'm meant to believe commercial marketing bs specs? ;) hehe
If it's not, I wouldn't buy from that manufacturer in the first place ;)
Robby Hoinsky
Re: SPL ?
#43 Post by Robby Hoinsky »
shane2943 wrote:Are these the Etymotics y'all are talking about?
that's the one.
Authorized BFM Builder
http://www.ArtofNoiseAudio.com
Retailer of Eminence and Dayton loudspeakers
el_ingeniero
Re: SPL ?
#44 Post by el_ingeniero »
Gauss wrote:I'm totally a tightwad when it comes to money, but I spent the $120 on molded musician's plugs from an audiologist. These have been invaluable. I even lost a pair (!!) and bought another. It's a good, comfortable fit, and best of all, I can hear clearly. At high volumes, I hear things others can't because their ears are being overwhelmed (like vents rattling.) Some of the best money I've spent as a musician - I can enjoy the music instead of being irritated by the volume.
I spent about $200 on a pair of Alien Ear IEMs I use for DJing. They seem to give me a nice 25 dB or so cut, so I can line up my sets listening at 80 dB while the PA is
cranking along at 95 to 100.
