Re: New Build - T30s and then Otops to follow
Posted: Thu Jun 06, 2013 2:13 am
Sussed = figured out.byacey wrote: I'm not sure what sussed means
Loudspeaker Design
https://billfitzmaurice.info/forum/
byacey wrote:I'm not sure what sussed means, but you're off to a bad start if you use 1.141 instead of 1.414.escapemcp wrote: It will be interesting to compare the voltmeter readings with what the amp thinks it should be putting out (allowing for the 1.141 multiplier - from the 3dB crest factor right?)
I reckon i have about 90% of the theory stuff on here sussed... even if i do sometimes use the wrong terminology!!... of course the more you know, the more you realize you don't know, so that figure can only go down!!!
Although there are other bits that they make this a grey area, thanks to so many different laws on this! I'm going to be getting back onto them to try to get a cash refund as I am so skint this month after having to buy an extra amp and other unexpected expenses. Failing that, they do have the DEQ2496 listed, although this is also out of stock... whichever comes into stock first, then I'm bagging it! I've been on their website so many times previously thinking "I'll have that", but when I have credit with them, I can't find anything I really wantCustomers do not have to accept a credit note instead of a full refund, repair or replacement if the item is faulty; see Your customers’ rights on faulty goods. Where a customer is entitled to a full refund, repair or replacement you should not mislead them into thinking that a credit note is their only option.
Isn't SPDIF 75ohm tho as opposed to the 110 of AES. Are they 'close' enough not to have to worry?sine143 wrote:i've always used a normal rca connector to run digital out from a cdj2000 to the digital in on the djm series mixers. works a charm, comes in about 3 db hotter than the analog signal too.
No.escapemcp wrote: Are they 'close' enough not to have to worry?
RCA is all I have coming out the back of the Behringer mixer. AES or TOSlink is all I have going into the DEQMissileCrisis wrote:Whatever you do don't try coaxial RCA to SPIDF XLR patching into a behringer product, it has issues. If you go digital go all the way and get an xlr-xlr aes direct.
Yeah, which makes it funny when you see these audiophiles insisting on 'medical grade glass fibre' for 1m toslink cables!Radian wrote:Digital communication failure mode is either "All Good" or "All Bad". There is no fuzzy in between area.
Aah, that's what I was after... tried the search, but it always brings up too many results!Radian wrote:See here: http://billfitzmaurice.info/forum/viewt ... 28&t=19865
There are convertors.escapemcp wrote:RCA is all I have coming out the back of the Behringer mixer. AES or TOSlink is all I have going into the DEQ
Yeah, that's the (new) plan... a bit annoying as really i need to fit the convertor into my flightcase as I'd rather have any runs in AES rather than SPDIF, and it is starting to get a tight squeeze in there - I'll just have to ram it in!Bill Fitzmaurice wrote:There are convertors.escapemcp wrote:RCA is all I have coming out the back of the Behringer mixer. AES or TOSlink is all I have going into the DEQ
As I've never used digital linking......for those of you that have - Is it really even noticeable in a live sound or DJ setting?Bill Fitzmaurice wrote:There are convertors.escapemcp wrote:RCA is all I have coming out the back of the Behringer mixer. AES or TOSlink is all I have going into the DEQ
I've worked in the medical profession for over thirty years (including operating theatre and intensive care units) and never even heard of that!escapemcp wrote: 'medical grade glass fibre'
