Page 13 of 21
Re: Introducing SPL Chart
Posted: Tue Mar 22, 2011 8:02 am
by Chris_Allen
Unfortunately at work, so don't have access tot he tools
Posted: Mon Jul 11, 2011 2:45 pm
by Harley
J110 vs W10
Posted: Mon Jul 11, 2011 3:03 pm
by DaveK
Harley wrote:J110 vs W10
Showing for the umpteenth time that bigger is louder
Posted: Mon Jul 11, 2011 6:14 pm
by Harley
Actually, just working out if I should use my spare J110 as a monitor with FOH mix or go to the hassle of building another W10. I like the shape of the W10 for a monitor and was surprised it was louder - decision made really
Posted: Tue Jul 12, 2011 2:55 pm
by DaveK
Harley wrote:Actually, just working out if I should use my spare J110 as a monitor with FOH mix or go to the hassle of building another W10. I like the shape of the W10 for a monitor and was surprised it was louder - decision made really
Not an apples-to-apples comparison. The W10 box is roughly the same size as a J112 and has similar response. The J110 is smaller and not as loud. That was the source of my comment that bigger is louder.
Posted: Fri Jul 29, 2011 2:39 am
by Dan30
Are there any charts available for the TLAH Pro? I want to compare it to the SLA Pro.
Posted: Mon Aug 08, 2011 2:15 pm
by Harley
Chris - are there any charts for;
J112 Melded piezos and 3012HO?
J115 Melded piezos and Kappalite 3015 ?
Also, is the J110M12 chart for the DLII2510?
Posted: Thu Aug 25, 2011 2:47 pm
by Chris_Allen
I'm finally updating the charts, so I'm looking for the gaps:
JBL SRX728
TT's
Posted: Thu Aug 25, 2011 3:01 pm
by Chris_Allen
Dan30 wrote:Are there any charts available for the TLAH Pro? I want to compare it to the SLA Pro.
Had a good luck but I can't find one.
Posted: Thu Aug 25, 2011 3:14 pm
by Chris_Allen
Dual driver Tuba 60
Posted: Thu Aug 25, 2011 6:02 pm
by Chris_Allen
I've now included an experimental '+' symbol - it will increase a map by a certain number of dB's that you specify:
Code: Select all
[spl]T48W24D3015+6,T48W24D3015&dbmin=80&fmax=200[/spl]
Not quite sure on the '+' char on the naming, so it might change. I've also increased the default width to provide more space.
Posted: Thu Aug 25, 2011 9:16 pm
by BassMe
Does anyone have TT with tang band in it?
Posted: Thu Aug 25, 2011 9:35 pm
Chris_Allen wrote:
TT's
I need to redo that one. The response will flatten a lot more with the reduced space loading. That chart dates back to the very early days, both HornResp and my charting skills have improved a lot in the interim.
Posted: Thu Aug 25, 2011 10:06 pm
Fixed it, this is the updated TT chart.
Posted: Thu Aug 25, 2011 10:35 pm
by Jon Barnhardt
Chris, any chance you can add the ls yorkville subs? Namely the ls1208 and ls808 subs?
Thanks!
