Titan 48x8 build
Five9teen
Re: Titan 48x8 build
#166 Post by Five9teen »
Just out of curiousity, are the holes in your access panel drilled large enough, so that the screws/bolts you are using spin freely enough allowing them to just dig into the flange and not "thread" thru the access panel. Also, tighten them in an alternating pattern, a little at a time.
2 X Frankensteiner Tops
2 X Frankensteiner Subs
1 X DCS255-4 10" TT
1 X DCS205-4 8" TAT
1 X DCS205-4 8" Dual TAT
Rectangular TLAH
SLA Center
2xSLA Pro 2x6
TUBA 30 Slims on the way
#167 Post by Tom Smit »
Five9teen wrote:Just out of curiousity, are the holes in your access panel drilled large enough, so that the screws/bolts you are using spin freely enough allowing them to just dig into the flange and not "thread" thru the access panel. Also, tighten them in an alternating pattern, a little at a time.
+1
