Links to everything you need for your BFD-build, in Europe.
Re: Links to everything you need for your BFD-build, in Euro
So a 1u rack panel that didn't fit the rack, didn't fit the hole spacing and didn't let you fit speakons...can you tell me where you got it from so that I can avoid it
2 x 3012 HO Jack 12 Lites
Subs? Big question mark!
This: http://www.audiospares.com/product.php? ... =62&page=4Jools4001 wrote:So a 1u rack panel that didn't fit the rack, didn't fit the hole spacing and didn't let you fit speakons...can you tell me where you got it from so that I can avoid it
Audiospares are normally pretty good (and very goddam cheap!), but this particular item was a false economy. In the description it is claimed that it is steel.... it's not, but rather alu. Next time I'm going with the folded steel option that is maybe a mm in depth, rather than this one, which is about 4-5mm deep, yet still bends as soon as you try plugging anything in! The one good thing about this item though is that you can screw M3 screws straight into it, and the alu is so soft (and deep) that the screw just bites itself a thread. I assume that this is by design, but seeing that the item doesn't actually seem to be designed, I think it's probably another mistake
Note: Jools - I can fit Speakons IF I 'front load' them, but that means that I will have to disconnect the leads from the chassis plug to fit the wire through the hole (something I am keen to avoid on a critical connection to my speakers)... rear loading is the way I'd rather go, as it doesn't require any of this faffing with cables, and looks better IMHO - I'll take some rig-porn pics tonight to post up here so you can all agree with me
- Chris_Allen
I believe AES is 110 Ohms, no idea what DMX, though, being a digital signal, it's either going to be there or not. A variation in impedance won't change the levels.escapemcp wrote:I think so... DMX cable is ok, isn't it?Chris_Allen wrote:Not wanting to dilute the thread with a DCX/DEQ conversation, are you using a proper AES cable of the correct impedance?
Get yourself over here!
http://www.behringermods.com/deq2496.html
OK, DMX is 120Ω, rather than 110ΩChris_Allen wrote:I believe AES is 110 Ohms, no idea what DMX, though, being a digital signal, it's either going to be there or not. A variation in impedance won't change the levels.escapemcp wrote:I think so... DMX cable is ok, isn't it?Chris_Allen wrote:Not wanting to dilute the thread with a DCX/DEQ conversation, are you using a proper AES cable of the correct impedance?
I have seen that mod site before. I was considering it, and looking at doing the DCX as well - pricing it up (2 DEQ ins & 6 DCX outs) was getting a bit expensive though! I never considered just doing the DEQ. In fact since I looked into it, I am now using the output from the DEQ for tops, so modding the DEQ only may be a good option - it's the tops that are going to be far more revealing of distortion than the subs. The only thing about those mods, is that after you add in all the costs, I might as well just have purchased a Driverack
For anyone attempting to build in the north-east of the UK, can highly recommend http://www.falltimber.co.uk/index.aspx
4x8' 12mm BB grade baltic birch for £25 a sheet.
Excellent quality and Matt who runs the yard a very helpful guy.
Also using the Everbuild Lumberjack 30min polyurethane as recommended earlier in this thread, seems to be working fine.
possible lab-12 alternative?
AD12-300SB http://www.ebay.co.uk/itm/371027807111?redirect=mobile
Technical Details
Thielle Small Parameters :-
Sensitivity
87.4dB
Nominal Power Handling
300W
Weight
9.0kg
Range
20Hz to 2500Hz -6dB
Cabinet Volume
Sealed
50 Litres
Ported
100 Litres
Impedance
4 Ohms
Qts 0.37
Re
3.6 Ohms
Vas 103.3 L
Le@1kHz
1.10mH
Mms 150g
Fs
24.6Hz
Cms 0.198 mm/N
Qms
2.76
Sd 514.7 Cu Cms
Qes
0.43
Bl 14.0 T-M
Xmax 15mm
Technical Details
Sensitivity
87.4dB
300W
Weight
9.0kg
Range
20Hz to 2500Hz -6dB
Cabinet Volume
Sealed
50 Litres
Ported
100 Litres
Impedance
4 Ohms
Qts 0.37
Re
3.6 Ohms
Vas 103.3 L
Le@1kHz
1.10mH
Mms 150g
Fs
24.6Hz
Cms 0.198 mm/N
Qms
2.76
Sd 514.7 Cu Cms
Qes
0.43
Bl 14.0 T-M
Xmax 15mm
The specs are OK, but the lack of a front gasket will be a problem in rear mounting applications, like the T60.Wingman wrote:possible lab-12 alternative?
I think that it would be possible to retrofit one, but yes one should remember to buy a gasket.Bill Fitzmaurice wrote:The specs are OK, but the lack of a front gasket will be a problem in rear mounting applications, like the T60.Wingman wrote:possible lab-12 alternative?
Anyone got a recent recommendation for piezos apart from CPC?
Just went to order some for my Jack only to find CPC are discontinuing them and have 5 left in stock. Not enough by 1
, only want a 6x flat array
Bother.keithgrif wrote:Anyone got a recent recommendation for piezos apart from CPC?
Just went to order some for my Jack only to find CPC are discontinuing them and have 5 left in stock. Not enough by 1, only want a 6x flat array
There's a whole bunch of 1016 clones, I think the original was Motorola's KSN 1016A. I tried to search UK for some but didn't come up with much, or they were expensive.
Might be time to order and ship from the USA...
Monacor.keithgrif wrote:Anyone got a recent recommendation for piezos apart from CPC?
MPT-016Bill Fitzmaurice wrote:Monacor.
Thanks for the replies, was really looking for a recommendation of a retailer in the UK. Ordered now from Thomann as I've had good service from them in the past.
A bit late, but http://www.specialistelectronics.com/pr ... .0490.html have them for £3.32 a pop. Maybe it'll help someone else later on.
EDIT: If they had them in stock
EDIT#2: Searching for the sku (110490 or 11.0490) may help find them, especially when combined with 'tweeter' or 'piezo'. Some places have these listed as IMG Stageline MPT-016 as well.
EDIT#3: For big orders, go straight to Monacor!
spongebob1981
Does anybody know of a 1-stop shop or online resource for all the drivers for a David either in London or Madrid? TY all!
(Using jacks as Home Theater sound tends to get loud too quickly
"Yep, deep orange" 2xJ10
(other site) 50W DIY Tube Head
"La música es el delirio. Bienvenidos al delirio."
