DR Line array stand (based Upon Tim Ards simple solution)
Tim A
#16 Post by Tim A »
Dave, can you give me some stand info?
Who makes them?
What is the base spread?
What is the height when retracted?
What is the height fully extended?
What is the per-stand weight capacity?
Thanks
DAVID_L_PERRY
#17 Post by DAVID_L_PERRY »
Tim Ard wrote:Dave, can you give me some stand info?
Who makes them?
Thanks
They came from a UK company called Studiospares. no manufacturers stamp is on the stand so imagine its a mass china made product ??
(Page 85 of the latest cat for any one who has it)
This is the web link (no details at all...!!)
http://www.studiospares.com/Product.aspx?code=448390#
They are listed as 80kg load in the catalog however I have seen what appears to be the exact same stand rated at 40kg...I would go with the 40kg rating to be on the safe side
This looks like the exact same stand and has dims listed
http://cpc.farnell.com/jsp/level5/modul ... 469154.xml
I will check all the dims for you tonight...
Dave
DAVID_L_PERRY
#18 Post by DAVID_L_PERRY »
Thanks
I checked out the stands last night. I have the tripod legs so that the dimension from the centre of the vertical post to the end of one of the feet is approximately 700mm (28") So that is a 56" diameter for the feet.
Each stand has an adjustable collet that can be moved up/down the main post so that it sets the base width.
I actually reduced the width by about 3" from the original stand setup so that the feet do not interfere with the adjoining stand.
other dims are as per the link
# Adjustable height: 1520-2300mm
# Maximum load: 40kg or 80kg (take your pick !!)
# Folded dimensions: 1475x160x150
# Weight: 9.02kg
Dave
Tim A
#19 Post by Tim A »
Ok, thanks!
DAVID_L_PERRY
#20 Post by DAVID_L_PERRY »
I have now done a few more gigs with these stands and will briefly add some more comments from real hands on gig use.
Very quick to erect. very quick to attach the support brackets (just loosen 4 bolts per side and slide on the bracket)
Its simple to lift the cabs and lights on. So far I have always had the help of a band member to lift cabs on/off, but as I know from setting it up in my garage its possibly as a one operation.
What I have found is that it is far better to wind up the stands yourself. With two people winding up the stand you can easily go up at different speeds - no good, and to be honest its such an easy one man lift its no problem.
I have decided for the moment to simply stick with the ratchet straps to hold the top cab in place, its quick and holds solid. The straps thread through the handles on my DR's
Once set up the stand is very,very stable, surprisingly so, and gives a nice defined area below the cabs so punters are lees likely to knock into the cabs as can be the case with a single tripod stand
The fixed 4deg angle of the lower cab suits my situation so far very well.
All in all its a big thumbs up for this approach
Quick, light, cheap and solid
Dave
DAVID_L_PERRY
#21 Post by DAVID_L_PERRY »
One ugly fella.....
Posted this just so that you can see the height that I like to have them set as a minimum...I am just about 6' tall...and clearly a handsome man. I had hair before starting building my first DR cab..... :D
PS...Its the camera man that was wonky...not the floor
Dave
Les Webb
#22 Post by Les Webb »
I've found that hair is completely overrated 8) 8)
Some men God gave hair. The rest of us He gave brains. :wink:
David Carter
#24 Post by David Carter »
Bill Fitzmaurice wrote:Some men God gave hair. The rest of us He gave brains. :wink:
Hopefully that means that as the hair begins to disappear, the brain power is increasing. :) If that's the case, then my future is bright (and not just when looking at my forhead!). :)
Dave
- 2 x Titan 39 (BP102 - 14"W)
Tim A
#25 Post by Tim A »
You're not bald, you're simply taller than your hair!
DAVID_L_PERRY
#26 Post by DAVID_L_PERRY »
You know TIm, since being bald as the preverbial coot from when I was 17 I thought I had pretty much heard all the good hair jokes...thats a new one......top of the class :lol: :lol: :)
Harley
#27 Post by Harley »
DAVID_L_PERRY wrote:... I thought I had pretty much heard all the good hair jokes...
Try owning a business in the blind industry for jokes!
It got to the stage where if I heard even one peep about a blind joke, there was another $20 on their service bill! I don't go through pain for free!
