Penn Recessed Casters W2080K/HD
bgavin wrote:I have a number of Penn and Harbor Freight fixed casters. For my needs, they require mounting to the lower reflector plate. I don't like casters hanging off the ass end of the cab. They have a tendency to buzz, and to snag the shins of the unwary.
For smaller boxes I like these:
http://www.partsexpress.com/pe/showdetl ... er=262-282 They hang about 5/8 inch, so a with pair of these on the opposite side
http://www.partsexpress.com/pe/showdetl ... er=260-770 you let the box rest on two wheels and two feet. The box won't roll and the wheels won't rattle.
Then put one of these on the cab and you're good to go. http://www.sciplus.com/category.cfm?subsection=20
The picture shows these with a plate for internal mounting, but it can be removed to mount the rig on the outside of a sealed cab.
Tom
#17 Post by Tom »
I JUST RECEIVED 8 OF THOSE SCIPLUS HANDLES SHIPPED FOR $47 total cost!
They look great. I'm building some Omni 10s, and will likely fit them into that project. Thanks for the tip.
#18 Post by LelandCrooks »
To internally mount those, drill out the holes and carefully pull tee nuts into the nylon. Works great.
