Dr2xx HF alternatives (Europe ship.)
For unmatched sensitivity.
Mishkin
Re: Dr2xx HF alternatives (Europe ship.)
#16 Post by Mishkin »
Bill Fitzmaurice wrote: Sat Nov 18, 2023 8:51 am The crossover high pass you'd need sooner or later, so build it. Use a pink noise source, which you can get as a download. Take an RTA of each, swapping them without changing anything else. Even a freeware RTA app is sufficient for comparison. I have this on my phone: https://play.google.com/store/apps/deta ... yzer&pli=1
great i will do it this way !
Another question: I am only going to be using 2 DR200s and want to mount them simply one on either side on stands . In the DR200 plans it refers to eminence adjustable top hats - Is this solely because the cab isnt square ? ie. can the internals of the cab accomodate a normal static top hat ?
If not, and i have to use one of these adjustable ones, would this be a suitable alternative to the eminence one ? https://www.thomann.de/gb/adam_hall_sm7 ... GoQAvD_BwE
many thanks,
Kairos
#17 Post by Bruce Weldy »
Mishkin wrote: Mon Jan 15, 2024 10:33 am [ Is this solely because the cab isnt square ? ie. can the internals of the cab accomodate a normal static top hat ?
You can put a normal one in there, but the speaker would be pointing up instead of at the crowd. The adjustable tophat lets you get the proper angle to the audience. I don't see any problem with the one you linked. You'll just have to do the math to make sure it will fit.
