Simplexx 12 Build
Re: Simplexx 12 Build
Don't sweat the coil positions. If you had high pass and low pass both on the same board you would want the coils wide apart on different axis to prevent cross talk between the coils on the low pass and high pass. With them on separate boards that's not a consideration, although you do want to keep them at least an inch apart so that they can't affect each others values.
argon
#17 Post by argon »
Thanks again!
