yes, eminence low drivers are no problem. only the 1" isn't available here.Grant Bunter wrote: ↑Wed Dec 16, 2020 2:37 pmHi!
Eminence is stocked at Thoman.de, so should be widely available through Europe...
Jack12 or OmniTop12
Re: Jack12 or OmniTop12
Understood.deroy wrote: ↑Wed Dec 16, 2020 3:25 pmyes, eminence low drivers are no problem. only the 1" isn't available here.Grant Bunter wrote: ↑Wed Dec 16, 2020 2:37 pmHi!
They do get eminence in though, so have access to whatever you want.
Send them an e-mail. it might be possible...
Also, with other brands, check the dimensions of the compression drivers carefully.
There's not unlimited room to fit deeper or wider than the recommended driver...
