Now I gone and done it. Silly me, I built a CNC!
Strange Kevin
Re: Now I gone and done it. Silly me, I built a CNC!
#16 Post by Strange Kevin »
That thing is Fantastic!!!!
- now I really want one!!
To save a little more time on cutting the baffle, you could have the CNC cut out the center and make one pass around the outside to mark your "line" then cut the outside diameter on the table saw. It may be less satisfying, but probably much quicker. :)
Great job!!
#17 Post by Chris_Allen »
I'm not sure what was more entertaining, the activity or the commentary!
Signalsdrone
#18 Post by Signalsdrone »
DIY CNC machine, outstanding!
James Champer
#19 Post by James Champer »
Padde298 wrote: Thu Sep 27, 2018 2:04 am WOW, I mean WOW!!!!
You beat me to it John... Truely impressed with your result! Do you have any prior experience building things like a CNC router? A 3D printer maybe..?
Thanks! And nope, never. Heck, most of the time I don't even think in three dimensions. Probably couldn't have done it without the Interwebs.
Funny you should mention a 3D printer. The two things I'm dying to do to her is to not only make her a 3D printer, but also a laser engraver! Not the kind that cuts steel mind you, but I wouldn't mind cutting some wood. That does get expensive however, you can sink some real money in powerful laser heads.
This may very well be a prototype of sorts. I really do want to shape steel as well, automated of course..
Now , if I can just find that mill/lathe combo on the cheep that I've had my eye on, I might be able to get started on a DIY CNC plasma cutter.
:shock:
James Champer
#20 Post by James Champer »
Strange Kevin wrote: Thu Sep 27, 2018 3:32 am That thing is Fantastic!!!!
Great job!!
That's a good idea but, that kinda sounds like work :D
As me daddy used to say; "Ringo, (He liked to call me that as a young impressionable lad) you'll never make money in music or art, so cut that hair and get a real job..".
Oh wait, it might have been; "Work smart, not hard son. Find something that you enjoy doing and you'll never work again.".
Yeah, that's the one I was looking for.. Certainly better than the oft heard; "Listen, if I want any sh*t outta you, I'll squeeze your head.".
Ahhh memories.
J_Dunavin
#21 Post by J_Dunavin »
:clap: :clap: :clap:
Excellent work sir, excellent!
jimbo7
#22 Post by jimbo7 »
Good job! Did you level your bed? Any wobbles from the X and Y lead rod?
James Champer
#23 Post by James Champer »
jimbo7 wrote: Fri Sep 28, 2018 6:34 pm Good job! Did you level your bed? Any wobbles from the X and Y lead rod?
Thanks, and nope, she really is tight as a drum. In fact a bit too tight in the last few mm of each of those axis. Nothing that hampers the operation really. but I am already thinking of a mod to hard rubber V wheels as an alternative to the bearing rollers. That might increase the workable space by a couple of inches in each direction.
jimbo7
#24 Post by jimbo7 »
James Champer wrote: Mon Oct 01, 2018 7:42 am I am already thinking of a mod to hard rubber V wheels as an alternative to the bearing rollers. That might increase the workable space by a couple of inches in each direction.
I'd make a dust shoe and vacuum system before you do that. My buddy rigged a harbour freight dust collector and homemade dust shoe to his and now you can do open heart surgury next to it. :chainsaw: Helped quiet it down too if you can believe that.
Ben
#25 Post by Ben »
Wow! Very impressive. You do good work.
Jack 12 (2)
Wedgehorn 6 (4)
