DIY Flood / upwash lights
James Champer
Re: DIY Flood / upwash lights
#16 Post by James Champer »
Cool!
You know, after I posted, it occurred to me that a member that doesn't sing, could have a headset on that he could use to cue the scenes by voice.
Hmmm, may have to slap one on one of my bass players one of these days. Not a one of them sings. It would be awesome if that worked as well as I think it would. :)
J_Dunavin
#17 Post by J_Dunavin »
You know... You could set up a physical switch in the bass food pedal.
Just throwing ideas around.
I think the headset mic would work, you would just have to go into the audio settings nin freestyler and select a freq threshold that would work for that situation.
J_Dunavin
#18 Post by J_Dunavin »
sorry for the spattering of info....
Here is the controller that i use to change address and settings of the flood lights, if need be.
https://www.nledshop.com/index.php?main ... sd2k8lo117
and i simply mounted it in this box, with a multi conductor cable, out to a 9 pin DSUB, that connects to the DSUB shown from the picture abovehttps://www.newark.com/webapp/wcs/stores/servle ... reId=10194
Bikewrench
#19 Post by Bikewrench »
I was checking out the website for the controller. Do you know the difference between these two? Seem to be similar price with similar features.
https://www.nledshop.com/fourchan/
https://www.nledshop.com/4chandmx/
J_Dunavin
#20 Post by J_Dunavin »
I believe it’s just the form factor. I checked the data sheet and they both can handle he same amount of current.
E-mail Jeff at their support email, he’s pretty good about getting back to you.
