3D Printed T48 Mini (AKA T9)
shawn_g
Re: 3D Printed T48 Mini (AKA T9)
#16 Post by shawn_g »
Here we go, the moment you've been waiting for... Blue line is the same driver in a sealed enclosure. White is T48 mini.
#17 Post by Tom Smit »
Interesting!
Are you using Audio Tool?
shawn_g
#18 Post by shawn_g »
Tom Smit wrote:...
Yeah. I have one those Dayton measurement mics for smartphones.
67baja
#19 Post by 67baja »
Bruce Weldy wrote:
shawn_g wrote:
67baja wrote:You should have went with a premium driver:
http://www.parts-express.com/tang-band- ... r--264-875
I'm amazed that exists. 2mm xmax!
A bit of a stretch for them to market it as a subwoofer when it only goes down to 90hz....and that's probably -10db.
Even better: http://www.parts-express.com/tang-band- ... m--264-950
It's good to 75 hz, but a bit more dollars. You'd think more cents due to the size, but no its dollars.
#20 Post by CoronaOperator »
67baja wrote: Even better: http://www.parts-express.com/tang-band- ... m--264-950
5.3mm x-max in a 2" driver :shock:
That thing will poke your eye out if you're not careful!
#21 Post by Tom Smit »
shawn_g wrote:
Tom Smit wrote:...
Me too. My SGS2 is very slow to respond with it, but my tablet is fine.
67baja
#22 Post by 67baja »
Yeah that think must turn itself inside out when the bass hits. $35 for a 2" driver seems a bit steep tho. However, if some will send me a 3d printed titan or tu a that can use that driver, I promise I will buy one and try it.
Rich4349
#23 Post by Rich4349 »
Nevermind the 1/10th scale model, how rare /expensive is a printer large enough to make the real thing!?
